SSL error no cypher overlap
Titillating
Assistant Community Manager
Sep 9, 2014
423
70
66
In case you missed the other thread check out this article
Here's the same problem from that same akamai.net ( 2 and 1/2 years ago)
http://www.zdnet.com/article/akamais-https-fail-sets-a-bad-example/
ironically just started seeing this error now again
The certificate is only valid for the following names: a248.e.akamai.net, *.akamaihd.net, *.akamaihd-staging.net, *.akamaized.net, *.akamaized-staging.net
Been following this thread, as well as the other. I've escalated this matter up to our network guys, who are looking into it. Progress has been slow, since we haven't been able to reproduce these, but we've been working with our CDN on it.
Titillating
Sep 9, 2014
423
70
66
For those of you getting the invalid certificate error (not the SSL error, which appears to have been resolved):
Next time you run into these, please ping forums.anandtech.com and let me know what IP address is returned. As @KillerBee pointed out, this is most likely an Akamai issue (and not an uncommon one at that) where some users are hitting the non-secure servers for whatever reason.
KillerBee
1,750
82
Just happened again.
forums.anandtech.com uses an invalid security certificate. The certificate is only valid for the following names: a248.e.akamai.net, *.akamaihd.net, *.akamaihd-staging.net, *.akamaized.net, *.akamaized-staging.net
Error code: SSL_ERROR_BAD_CERT_DOMAIN
Then did 3 quick pings in a row ...I
The IP changes quick so not sure how valid a test that is for which IP caused it.
23.55.57.8
23.55.57.10
23.55.57.25
C:\Users\joe>ping forums.anandtech.com
Pinging e12200.e12.akamaiedge.net [23.55.57.8] with 32 bytes of data:
Reply from 23.55.57.8: bytes=32 time=17ms TTL=57
Reply from 23.55.57.8: bytes=32 time=16ms TTL=57
Ping statistics for 23.55.57.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 16ms, Maximum = 17ms, Average = 16ms
Pinging e12200.e12.akamaiedge.net [23.55.57.10] with 32 bytes of data:
Reply from 23.55.57.10: bytes=32 time=15ms TTL=57
Reply from 23.55.57.10: bytes=32 time=16ms TTL=57
Ping statistics for 23.55.57.10:
Minimum = 15ms, Maximum = 16ms, Average = 15ms
Pinging e12200.e12.akamaiedge.net [23.55.57.25] with 32 bytes of data:
Reply from 23.55.57.25: bytes=32 time=19ms TTL=57
Reply from 23.55.57.25: bytes=32 time=31ms TTL=57
Reply from 23.55.57.25: bytes=32 time=23ms TTL=57
Reply from 23.55.57.25: bytes=32 time=15ms TTL=57
Ping statistics for 23.55.57.25:
Minimum = 15ms, Maximum = 31ms, Average = 22ms
KillerBee
1,750
82
note: Be sure to check you don't already have an Exception for the certificate in your browser
Titillating
Sep 9, 2014
423
70
66
Alright, we believe we've identified the problem, and a fix was pushed live a few moments ago. Many thanks to @KillerBee for the assistance :)
If either of these errors come up again (SSL or invalid certificate), please let me know right away.
nakedfrog
63,428
19,829
Still none of the cypher errors on my front, and I haven't seen the Akamai one at all.
KillerBee
1,750
82
The error showed up again today.
forums.anandtech.com uses an invalid security certificate. The certificate is only valid for the following names: a248.e.akamai.net, *.akamaized.net, *.akamaihd-staging.net, *.akamaihd.net, *.akamaized-staging.net
Same name but different IP
Pinging e12200.e12.akamaiedge.net [204.237.142.26] with 32 bytes of data:
Reply from 204.237.142.26: bytes=32 time=12ms TTL=57
C:\Users\joe>date
The current date is: Sun 09/18/2016
Enter the new date: (mm-dd-yy)
C:\Users\joe>time
The current time is: 12:09:44.95
Enter the new time:
KillerBee
1,750
82
... followed by another 20 minutes later (same error) with new IP
Pinging e12200.e12.akamaiedge.net [72.37.164.245] with 32 bytes of data:
Reply from 72.37.164.245: bytes=32 time=17ms TTL=57
Spacehead
13,067
9,858
I just got this too maybe 5 minutes ago.
forums.anandtech.com uses an invalid security certificate. The certificate is only valid for the following names: a248.e.akamai.net, *.akamaized.net, *.akamaihd-staging.net, *.akamaihd.net, *.akamaized-staging.net Error code: SSL_ERROR_BAD_CERT_DOMAIN
Here's the ping info:
C:\Documents and Settings\xxx>ping forums.anandtech.com
Pinging e12200.e12.akamaiedge.net [65.202.184.170] with 32 bytes of data:
Reply from 65.202.184.170: bytes=32 time=51ms TTL=60
Reply from 65.202.184.170: bytes=32 time=50ms TTL=60
Reply from 65.202.184.170: bytes=32 time=52ms TTL=60
Reply from 65.202.184.170: bytes=32 time=65ms TTL=60
Ping statistics for 65.202.184.170:
Minimum = 50ms, Maximum = 65ms, Average = 54ms
I'm using Firefox 47.0.1 if it matters
Titillating
Sep 9, 2014
423
70
66
Ack. Thanks, guys. I'll bring this up during today's meeting. Appreciate you guys including the ping results.
dualsmp
1,627
45
My browser flip flops from partially encrypted to fully encrypted depending on which page I'm on.
This very thread the first two pages are shown as partially encrypted, however the 3rd page (the page I'm responding on now) shows fully encrypted.
Edit: Maybe the first two pages show partially encrypted because both have images on them linked from other domains?
Spacehead
13,067
9,858
Yeah, that's it. It had me confused for a little while too till i realized. If someone posts images from a https hosting site you won't get the mixed content alert.
Reactions: Ken g6
Eug
24,175
1,815
I was getting this on Win 7 and Chrome last week. iOS 10.0.1 was fine but I just upgraded to 10.1 beta and Safari now gives me this. Not sure if it's related.
renz20003
2,714
634
Same issue.
iPhone 5 with iOS 9.3.2
Pulsar
5,224
306
Same issue. Chrome.
This server could not prove that it is forums.anandtech.com; its security certificate is from a248.e.akamai.net. This may be caused by a misconfiguration or an attacker intercepting your connection.
nakedfrog
63,428
19,829
+1, Firefox, seeing this error:
Reactions: sandorski
Ken g6
Moderator
Dec 11, 1999
16,801
4,784
75
I finally added a permanent security exception for this on my desktop.
allisolm
Administrator
Jan 2, 2001
25,364
5,069
Got the invalid security certificate thing yesterday and again today.
KillerBee
1,750
82
It seems to work for me too after adding it.
At least now when I get banned again I can blame it on the disgruntled Akamai ex-employee posting in my name after intercepting my password :D
Thankfully none of my banking sites seem to use Akamai
Reactions: Ken g6
Titillating
Sep 9, 2014
423
70
66
Many apologies for the long, long wait on this.
We're fairly certain that all these invalid cert issues should now be resolved. The Akamai staff have taken a number of steps internally (the issue was on their end) and assure us that this should not happen again. If it does though, please let us know and we'll go right back to yelling at them about it ;)
KillerBee
1,750
82
Oh well, it's still happening - after reloading the page (was using the 'new posts' link at the time ) a couple times it works again.
10/22/2016 @10:12 AM EST
23.55.57.147
23.55.57.115
10/22/2016 @10:50 AM EST
23.43.165.203
iCyborg
1,386
94
Same error here:
C:\Users\***>ping forums.anandtech.com
Pinging e12200.e12.akamaiedge.net [209.148.192.75] with 32 bytes of data:
Reply from 209.148.192.75: bytes=32 time=17ms TTL=59
Reply from 209.148.192.75: bytes=32 time=19ms TTL=59
Reply from 209.148.192.75: bytes=32 time=14ms TTL=59
Ping statistics for 209.148.192.75:
Minimum = 14ms, Maximum = 19ms, Average = 16ms
Spacehead
13,067
9,858
I just got warning from Firefox:
Your connection is not secure
The owner of forums.anandtech.com has configured their website improperly. To protect your information from being stolen, Firefox has not connected to this website.
forums.anandtech.com uses security technology that is outdated and vulnerable to attack. An attacker could easily reveal information which you thought to be safe.
Advanced info: SSL_ERROR_NO_CYPHER_OVERLAP
(Not secure) Try loading forums.anandtech.com using outdated security
Ping results:
Pinging e12200.e12.akamaiedge.net [65.151.23.144]
(i assume that's all the info you need?)
I was in OT at the time reading the "What do you guys do on the weekend?" & clicked to go to page 2 when it happened.
