Beautiful_Life
The discussion is pretty silly. Even if the wear leveling doesn't work very well, at the current rate I'm writing to it, there is no way the cells are going to wear out before my 3 years warranty is up and I believe in 3 years time the drive is going to end up in the dustbin.
Although it's wrong, even if only 60GB of cells were being written to that works out to just 12 write cycles, let's make it 21 to be super conservative. That works out to 7 per month 84 per year, hardly going to touch the 1000 conservative cycles we have. Furthermore, it's not like I'm gonna reinstall my OS and programs every month. It's a new PC so I had to redo things a few times to get them right, now that it's settled down I don't see myself doing it again. Also of the 80Gb HDD I have, 6GB has been set aside to replace any cells that do die off. Data is being moved around the SSD all the time and the controller is smart enough to manage them so that a dead cell won't affect the data integrity or the drive's performance.
Using Ramdisk and disabling every single feature that writes to the disk is just being a plain paranoid or tweak freak.
Btw, you should check out Anand Tech's very interesting article on SSD that explains wear leveling pretty well.
