What splitter do I need for splitting an antenna signal and which splitter for the cable? Will any splitter do both?
If I have this right:
The HDHomeRun Dual Model # HDHR3-US.
Can be used for OTA or clear QAM but not both at the same time due to only having a single coax connection on the back.
I have a both a antenna and basic cable (comcast) where I am at.
I am planning to setup a currently unused PC to test as a HTPC.
And if everything works OK getting another HDHR3-US and using one for OTA and one for cable.
I want to connect the HomeRun without disabling the current setup. The splitter will be for testing use only! So cheap is better. But I do not want the splitter to be the reason I can't get it to work. So the price is flexible.
I would rather purchase it from amazon. That is where I plan on buying the HomeRun.
