split water inside my t.v
Ryen
hi , im a crisis here , I had water on top of my 21 inch t.v and y ou know how on back of t.v's there are holes , well i accident'ly hit the dvd wire on top of my t.v and it spilt the drink inside the holes , and the screen turned all blue , u can still watch it , but its all blue , it just happended a few seictions ago , well the colors come back later? i quickly got towlers to dry it , am i suspose to open it up?
You should not open it. Even when unplugged, a CRT has high voltage capacitors that could hurt you. It's quite likely that something has shorted out and it will need repair. If you have a warranty from the place you bought it, contact them, otherwise contact the manufacturer. I wouldn't suggest using it in the meantime, since you don't know if all the water is dry inside.
