Speed problems with GeForce 2 Ultra
agnusdei
I just got my Inno3d GeForce 2 Ultra (64mb RAM) and for some reason, when I look in FuzzyLogic 3, it says the AGP bus is only 63.5, even in a game. Shouldn't it be much faster? I used to have a RIVA TNT-2 with 32mb of RAM and I'm not even noticing much of a difference. I think I may need to adjust some bios settings but, I'm not sure exactly what...... maybe this will help
Inno3d nVidia GeForce 2 Ultra with 64mb of ram
MSI K7T266 Pro-2 RU
1.4Ghz Athlon XP
512 DDR Ram
Win2000 Pro SP2
Detonator 12.41
Thanks! I appreciate it!
I have a similar situation with my Asus A7V133. With the FSB set to 133 MHz in the BIOS (multiplier @ 10.5), Sandra says that it is 134.3 MHz and my AGP bus is at 67 MHz. In my case, Asus may have set the clock generator (?) slightly faster. MBM5, Sandra, CPU Stability Test & CPU MathMark all say that my 1.4GHz T-bird is running @ 1.41/1.411 GHz. You may have the reverse of what I have. A 63.5 MHz AGP bus suggests to me a FSB of 127 MHz, a difference of 6 MHz. Bump your FSB to 139 MHz and see if that works for you (may be a BIOS or jumper setting, check your manual).
