CycloWizard
If you google "Mercury perihelion," you can find quite a bit of information to back this up. Einstein himself computed the precession of Mercury's perihelion as perhaps the first experimental validation of part of general relativity. Newton's formulation failed to predict it correctly due to the assumption that gravity propagates instantaneously.Originally posted by: Foxery
Wait, what? I'll hardly argue with something like Hawking, but my novice attempts to visualize a solar system responding to "slow" gravity makes me imagine that, at the best case, planets farther away from the sun will have increasingly eccentric (e.g. acutely eliptical) orbits, and in the worst case, will be unable to maintain any stable orbit. As far as I know, they remain pretty regular.
On an even larger scale, the idea that galaxies are attracted to each other's former positions on a million-year delay doesn't sit well with me at all. This would result in very chaotic movement. (on a comic time scale, so perhaps beyond our ability to measure)
edit: For those of you having a hard time accepting that even the curvature of spacetime cannot occur faster than the speed of light, it might also be worth addressing the blanket analogy. If I try to make a "dip" in a blanket for my ball to roll into, the blanket's deformation also proceeds over a finite amount of time, with the maximum velocity fixed at the speed of sound in the material of the blanket. It simply takes a finite amount of time for the forces to propagate through the blanket material to cause a deformation at a remote location. For example, what happens if you pick up a bedsheet at one end and shake it? Depends on how fast you shake it. If you shake it an infinitesimal amount infinitely fast, it will still take the length of the bedsheet divided by the speed of sound in the sheet for the far end to move.
