IEC, what case will you be using? I was originally going with a Fractal Define S but it was too tight with both Magicool rads even though they were slim. I was afraid of there not being enough room for the Asus CH6 so I opted for a Thermaltake V51. I thought it had enough room in the roof for the EK CE420 but again too tight for my tasts so I'm going with dual Magicool G2 slim 360 rads with 6 XSPC 1600 rpm 120mm fans controlled by a fan controller. Since I'm only cooling the cpu it is really overkill but put in both rads if I eventually WC a single Vega.
I'm going to pair the WC'd 1800x with 2 air cooled reference Sapphire RX480s-8G in CF. Should be fun!😀
I'm actually going to be using two cases:
Corsair Air 540 will house the PC components (I have one on hand)
Thermaltake Core P3 SE will house the water cooling components (dual pump housing/res + 420mm and 360mm rads)
https://www.newegg.com/Product/Product.aspx?Item=N82E16811133317
This should let me get away with air cooling the graphics card(s) while piping most of the CPU thermal output to the external rad box (i.e. the Core P3 SE)
Yeah, it's overkill and absolutely excessive, but I already had the radiators and I figured it's a good way to build a higher flow equivalent to a MO-RA3 or similar.
