speaker problem
thursday22dp
195
my speakers sound like crap on a new computer. They sound fuzzy without music playing when the volume is barely up.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Does the problem do away if you plug them into something else? (cd player, etc.)
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Headphones plugged into the speakers or plugged into the soundcard directly?
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Does the static go away when the headphones are plugged into the soundcard?
thursday22dp
195
well i stopped the static not really sure how but i did. Now only the left speaker works which is wierd since the right speaker is the main one
imported_rod
1,788
Your problem may be that your volume is cranked all the way up. Since AMD's onboard sound isn't brilliant, when you push it to max, it sorta sucks.
Try turning down all of your sound levels in windows, then turning the sound up on the speakers.
See if that works.
RoD
