- Dec 10, 2005
- 29,269
- 14,678
- 136
Originally posted by: randalee
Get some nice headphones. They can sound much better than your 2.1 setup likely, anyhow. You can put spikes on your sub to try get it off the floor a bit, and reduce the amount that actually contacts the subfloor, but a sub is a sub, man. They're gonna hear it, no matter HOW low you play it. Low frequency travels WELL.
I have headphones already. I plan on using them in the future at night. I was just cooking dinner though and wanted to have some music on. I don't exactly have an 35' headphone cable. I just let myself get carried away with the volume. I admit, it was a little on the loud side.
I'll probably try to get some thick rug to put under the woofer. I already moved it a little away from the wall. I'm going to look into getting a thick doormat, it would be the perfect size to fit under my woofer and I could keep using it during the day. I don't even have it up that high.
