You might want your spaceship to have wings if ever you had the want/need to enter a planets atmosphere...? Unless of course you ship operates in a self contained zero gravity field, then shape would not matter.
I'm surprised no one has posted this yet.
Hell, there is more than one of them.
And any "space ship" with a similar requirement (controlled/piloted atmospheric use, reusable for re-entry OR flight) would need a similar design. All this talk about fuel and structure and propellant obviously ignores that these fictional vehicles have overcome these limitations with things like fusion, zero-point energy, and mass-less (or super-advanced ion-type) propulsion.Probably because they are not really spaceship, rather reentry vehicles.
It produces a great deal of lift, and uses conventional control surfaces to maneuver. It is flying as much as any aircraft with no thrust.Space shuttle doesn't produce lift and doesn't fly. It just falls inefficiently and non aerodynamically.
Because actual space 'flight' mechanics would be boring. Even with thrust vectoring you wouldn't really turn, you'd just rotate around your center of mass until you're pointing the right way. You never cancelled out that original vector of travel. So you'd just be tumbling around in space. And nobody wants to watch a bunch of spinning pieces of metal for 2 hours.
I believe an atmospheric air breathing rocket is the first step. A rocket that has an intake an compressor stage like a jet engine that is then able to switch to internal onboard oxidizer as it leaves the atmosphere. Carrying oxidizer is a huge mass component in bipropellant engines (bigger than the fuel tanks).
Problem is you need a LOT of oxidizer and the atmosphere just isn't that dense, compounded by the fact that it gets less dense very quickly with altitude. Compounded further that practical rocket fuel AFR requires more oxidizer than fuel. Oh, and unlike a tank of 100% pure liquid oxygen or nitric acid or whatever your onboard oxidizer is, air is only 20% or so oxygen.
Wings are aesthetically pleasing is the top answer
A spaceship sized cue ball in space is hardly intimidating
Wings also provide hard points to mount forward facing weapon systems
And as mentioned if the ship plans to enter planetary atmospheres ala space shuttle
But yeah independence war had an awesome Newtonian physics engine. I miss that game so much.
Only if you plan to only fly in atmosphere with high percentage of oxygen.
You forget though, NASA hasn't had a manned craft to fly outside our orbit in many years. The Saturn V rockets were the last era of manned crafts that had the thrust and fuel capacity to travel from Earth to the moon in a timely fashion.
Rockets are practical, but not very reusable due to the spent fuel sections breaking off and becoming space-junk. This is why the shuttle program was a success...reusable craft. Hollywood and comics only try to keep up with the latest technology because it's just cooler. No one wants to see a Saturn V and it's tiny payload.....though they are probably the most amazing craft to ever come out of NASA. (thrust and fuel capacity are crazy on those things)
the 2D part was a little simplistic as wellThis is why "Asteroids" is the best space shooter game of all time. They managed to get the physics right! (other than possibly the part with the whole teleporting across the universe at the "edge")
I heard that for a ship to travel conventionally close to the speed of light, it will need some form of shield and design which can protect it from collisions with mere individual atoms floating in the vacuum of space.
That's why in hard sci-fi you put a kilometer thick chunk of Ice at the front of the ship.
Doesn't matter. Bad guys can't hit anything anyway. Or if they are very skilled at aiming, their guns will jam. Star Wars taught us that even laser-based weapons can jam, even without the aid of raspberries.Of course they need wings. That way they have more surface area per unit of volume, making them more vulnerable to enemy fire.
Hangs in the air in precisely the same way that bricks don't.
Or just use electromagnetic beam weapons of various wavelengths. Phasers, lasers, masers, whatever. No need to do crazy maneuvering if you can just puncture their hull at the speed of light. Maybe try to slice off their wings, just to demoralize the pilot.Pretty much this! Accelerate towards enemy for a day, shoot laser at engagement range for 20 seconds as you fly past. Decelerate for a day. Accelerate back towards enemy for a day...
Or you drop a bunch of diamonds, tungsten, whatever as you approach with high velocity. Enemy poof dead from hyper-velocity impact.
Your scaling is off. The "asteroids" are masses of galactic superclusters. It really is wrapping around the Universe.This is why "Asteroids" is the best space shooter game of all time. They managed to get the physics right! (other than possibly the part with the whole teleporting across the universe at the "edge")
Star Wars: You've got C-3PO, a robot capable of speaking a few million languages, but then there's R2-D2, who only squeaks and beeps. A crappy ancient PC can at least synthesize Microsoft Bob's voice. Portable GPS or smartphones can synthesize something more reasonable than that. Couldn't they have just duct-taped a cellphone to his head, plug in a serial adapter, and have it translate?Good point.
I don't mind some stylistic design elements in spaceships, but most of the time they go overboard. It also matters what kind of scifi it is, too.
