SP2208WFP Monitor Webcam Problem
coolkatz321
447
Whenever I try to use the webcam on the monitor, and put it at any resolution above 320x240, the picture begins to flicker and have these bizarre color blocks everywhere. I'm running the most up-to-date drivers on my graphics card (Radeon X800XL). Anyone have any ideas? Thanks!
robisbell
Banned
Oct 27, 2007
3,621
make and model of webcam.
is the X800XL from EVGA or someone?
what program are you using to pull up the webcam.
coolkatz321
447
I'm using Dell's own program... if there's a good 3rd party one I'd be glad to try it. The card is ATI Branded and direct from the company.
Narse
Moderator<br>Computer Help
Moderator
Mar 14, 2000
3,826
Is it possible that the webcan is running on USB 1.1 instead of USB 2.0? make sure the cam lead is plugged into a USB 2.0 slot.
