sp-94 installation problem
Dutchmaster420
1,116
ok i have an sp-94 i just got from a buy sell trade forum...it came nice w/ everything except directions so i had to follow the ones on thermarights website which are crappy...
alright i installed the black plate thing on the back side of the motherboard with the cpu shaped ruber thing facing down in the case...then screwd it it from the top...then placed the heatsink on and then screwed into place
then booted up and went into hardware montior and cpu as 78C....immeditaly turned pc off
what steps did i do wrong?
Dutchmaster420
1,116
fixed it....im getting 41 idle right now and asus probe says cpu fan below threshold with a value of 0...is this alright as i dont have a fan mounted to it yet
FelixDeCat
31,054
2,691
That pad is supposed to be facing towards the backside of the cpu not the box! It helps to prevent shorting out the CPU.
edit: like this -
..._...... <cpu
--------- <motherboard
_/-\_
not this-
..._...... <cpu
-\_/-
