Southwest flight 1380 makes emergency landing in Philadelphia after engine failure
Puffnstuff
16,256
4,930
Normally I wouldn't post this as engine issues are a common problem forcing the aircraft to land without incident. However, today southwest flight 1380 from LaGuardia experienced an engine failure that managed to penetrate the cabin injuring a passenger seated in aisle 17 that later died at the hospital. Passengers said that she was being sucked into the missing window space as other passengers futilely tried to plug the hole.
https://www.cnn.com/us/live-news/southwest-flight-emergency/index.html
Puffnstuff
16,256
4,930
Here's some footage from inside the cabin during the inflight emergency.
Here's an explanation of the problem.
Svnla
17,986
1,388
I saw that story earlier today at lunch. Now I am a bit leery because I always pick window seat while I travel by airplane. It would not be good if this happened in the ocean (trans Pacific/Atlantic flights). Goodness.
Nov 30, 2006
15,456
389
121
I saw that story earlier today at lunch. Now I am a bit leery because I always pick window seat while I travel by airplane. Goodness.
Just don't sit perpendicular to one of the engines and you should be relatively safe.
Indus
16,601
11,410
The engine blew at 32500 feet and shattered the window. At that altitude its a miracle the plane didn't break up due to rapid decompression.
Great job by the pilots guiding it back to the ground and saving almost everyone.
sdifox
101,161
18,199
yikes. Good job flight crew on getting it back on the ground safely.
Edit heard the recording. The pilot was cool as a cucumber.
BUTCH1
20,433
1,770
These engines spin at great speed and supposedly the cowling would stop projectiles from hitting the fuselage, it's far from foolproof it seems.
bshole
8,315
1,215
OMIGOD..... I.... AM....... A...... HERO!!!!!!!!! Do you see those two yellow fire trucks by the jet? They are running on 100% BSHOLE software! I wrote dat software around 2000 and have only had to mod it slightly since then (for expanded capability). Pump and roll software is cool as hell... In case you are interested, the controllers were using the Infineon C167 micro. It was the first project that I ever worked on that involved the CAN bus. I am now working with ARM micros which I prefer so far.
Puffnstuff
16,256
4,930
Even more information now as passengers had to pull the fatality, Jennifer Riordan, back into the aircraft after she hung outside the window for several minutes until enough people could pull her back inside the aircraft and place her back in her seat. A nurse performed CPR on her once she was back inside.
I can only imagine what the shock of being hit by shrapnel followed by the shock of striking the window frame did to her body followed by a prolonged period of low oxygen and freezing temperatures. She is survived by her husband and two children.
http://www.koat.com/article/albuque...er-flight-experiences-engine-failure/19844383
Linux23
11,374
741
oh god that is terrible. :(
Jan 25, 2011
17,188
9,722
Isn't this also the first death sure to airliner malfunction/crash on Southwest period?
Depends how you look at it. One went off the runway in a snow storm and crashed into traffic killing a 6 year old. The only other death was a guy who was restrained after trying to storm the cockpit and died of asphyxiation.
Reactions: Thebobo
Exterous
20,612
3,834
It's pretty rare so you're still more likely to die on the way to the airport than from the flight itself. There seem to be mixed reports so far on exactly what happened to the poor woman but I wonder if she was wearing her seatbelt or not. I always keep mine on due to the turbulence injuries and this so I'm curious to know if that would have mattered or not.
Mr. Martinez, the digital agency owner, said that amid the mayhem he bought Wi-Fi service so he could reach out to loved ones. He struggled to keep his focus, entering his credit card information digit by digit.
I guess thats one way to sell inflight wifi...
bshole
8,315
1,215
Hell, the pilot seems 10X as calm as the controllers on the ground. In any event, they were sorta lucky in that none of that flying shrapnel disabled any of the hydraulics and they had control throughout it seems.
Yep. A lot of times it does and that tends to make everybody dead. I think they have like three redundant lines.
DrunkenSano
3,892
490
It is also a reason why you should have your seatbelt on at all times even without turbulence unless you are moving about the cabin.
UNCjigga
25,715
10,471
I thought the runway overshoot killed someone on the ground though, not inside the plane.
Puffnstuff
16,256
4,930
I agree that they should be worn as a precautionary measure considering that we are required to wear them while driving our cars because accidents don't announce themselves beforehand. I can only imagine what those people felt and the struggle they went through to keep her body from leaving the cabin.
