gaidensensei
Banned
- May 31, 2003
- 2,851
- 2
- 81
For once I wasn't expecting this in the thread while reading through. Was looking for the witty remarks. That pic really made me lol when I reached it.
Why pussy footing around with softwood like Brazilian Cherry with 2300~2400 Janka when harder wood like Lignum Vitae (guayacan, pockenholz) at 4500 Janka exists?A: Concrete/tile board with a thin layer of foam over it. The foam comes on a roll and is normally used under hardwood anyway. The only weird thing would be the concrete board. The concrete board is dense to reduce noise penetration. The foam will damp vibrations. This will cost roughly $1 per sqft, and make your floors a half inch thicker, assuming you are already having the floor replaced. A half inch thicker floor will probably add some labor cost with non-flooring items, like removing and replacing all the baseboard and shoe molding (if any), cutting doors, cutting door frames/jambs etc. Depending on the room, this could get quite costly.
B: Use denser hardwood. This could easily get very pricey. Brazilian Cherry (really a rosewood) is much denser than Red Oak or Maple (most common hardwood flooring in NA) and far more expensive. Most high density wood is imported, rare, and super expensive.
C: Use tile instead of hardwood. Over one inch of stone and concrete on the floor will keep out a lot of noise. Far better for this purpose than any wood.
D: Why does a teenager, living at home, with no job, and very little sense, need to know this?
Bamboo looks amazing on my floor but I keeps getting scratches & dens because it is pretty soft.Strand bamboo is a reasonably priced uber dense product. That stuff is like battleship armor. You can pick it up for around $3.00 to $3.50 a sq/ft. It's only .55" thick though and not the more common .75" of "real" hardwood.
Strand is a whole different beast. It can be over 3300 psi on the janka scale.
You guys are confusing harness with density. To refresh, density = mass/volume. Diamond is the hardest thing we know of, and something like Plutonium is the densest. Plutonium is pretty soft, but would make a much better sound insulator than diamond. Diamond flooring would be pretty sweet though! (I'm looking at you Mr. Scientist)
Or instead of magnets you can go with RSIC clips.
