Hello, i currently have SoundBlaster Audigy Platinum ex with the external audio bay (SB0110), the soundcard (sb00090) and all the other features.
I got this bundle complete for 10 euros last year, and i'm since using them on my main pc (win10,Ryzen 1600,16gb,rx 570 (8gb)) connected with a pci to pci-e adapter and everything works perfectly fine so far (with custom drivers).
I'm planning on doing an upgrade by buying a used SoundBlaster Xtreme Fi (SB0460). However, i couldn't find someone who sells the original external bay (SB0250) that came bundled with the x-fi soundcard.
And for this reason, i wonder if it's possible to plug the bay that i have with the newer soundcard. Considering they are both connected via IDE interfaces this should work. Does anyone know if it is possible ? if it can work ?
Thank you for your time and pardon my English.
I'm attaching an image of the pack that i have
