sound volume problem - Audigy and z560
joeld
341
This is a pretty wierd problem:
I was experimenting with the surround mixer in the audigy settings, and i clicked mute on the master volume during the surround sound test at the top of the program. Of course, the sound stopped, but when i unchecked mute the sound only came back at about half volume. I say, what the heck!?, so I reboot and the problem is fixed. To make sure it was a one time problem, i go back in and repeat the same procedure and the sound came back at half volume again! This time when I reboot, the sound remains at low volume! Just so you will know the decrease in volume, i used to run my windows volume at around 25% with all other settings in the volume control at 25% as well, and the speaker volume around 30-40%. Now, to get the same sound I have to run windows between 50 and 75% volume (with all other volume controls at 75%) and the speaker volume around 40%.
Has anyone had a similar drop in volume after changing a setting in the audigy or live or can anyone give any advice to help me?
Thanks,
joeld
ChrisPi
29
Hi, I just got an audigy and z-560 set as well. I don't know why your volume is dropping. However, when I got my set I looked on 3dsoundsurge.com's forum for suggested volume levels. They said to leave the master volume in the surround mixer at a notch below 100% (I interpreted that as 90%) and the bass and treble settings at 50%. I had my master volume low like you and I was getting distortion and clipping. Another volume abnormality I still have is that on low volume the front right speaker is slightly louder and brighter than the left. When I go to normal volume though it evens out. Try posting your question on 3dsoundsurge.com's forum in the speaker or soundcard sections - the people there are helpful and the moderator Mark always gives good advise.
joeld
341
Thanks for the tip, i'll be sure to do that tomorrow.
That reminds me, the reason I was fiddling with the settings was because my REAR left speaker was higher and brighter than the rest :) the Wave/MP3 volume fixed mine though. at 50% volume on that, both rear speakers were louder, and at 100% on the wave/mp3 it was fine.
