Sound upgrade?
VanTheMan
1,060
I'm thinking about upgrading from the onboard sound on my A8N-SLI. Is there a fairly inexpensive card (<$30) that will be a worthwhile upgrade?
VanTheMan
1,060
Thanks for the reply. I was looking at that card on Slickdeals this morning. I currently have this speaker setup on my computer. It's 5 years old, but I think it does ok. I mainly game and occasionally listen to music. I appreciate any advice, since I know very little about sound equipment.
dderolph
619
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Originally posted by: dderolph
Originally posted by: YOyoYOhowsDAjello
For just stereo usage, a Chaintech AV-710 would be a good card.
If you have a multichannel set, I would suggest saving up for something a bit better... like this http://forums.anandtech.com/messageview...atid=40&threadid=1977678&enterthread=y
I second this card. Actually, it might be fine with 5.1 speakers also.
Newegg sells it: http://www.newegg.com/Product/Product.asp?Item=N82E16829120103
A bit cheaper at ZZF
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=292003
VanTheMan, with 2.1 speakers I think that card would be a good match.
You can learn more about it here and how to use the rear DAC for better quality output.
http://www.avsforum.com/avs-vb/showthread.php?t=364771
