<< If you use the Hollywood + then you can also use its SPDIF output. Sure it's coax but at least it's digital. >>
Unfortunately, I cannot use the SPDIF output, as the COAX input on my receiver is taken. I need an Optical solution, hence the Sound Blaster.
Are there any sound cards that have an Optical out from the CARD ITSELF? I will have limited 5@1/4 bays to use with this rig. I need an Optical out from the back of the machine.
Thanks!
