- Jul 25, 2009
- 61
- 0
- 61
So I have a Xonar Essence STX sound card, and a ASRock motherboard as seen below, and a 7950 GPU. I JUST built this PC, and for some reason I neglected to tell the people in my build thread that I had a sound card. Basically, the GPU and sound card are pretty much touching, which is no good, so I need a bigger motherboard. Here are my specs so you know what's compatible:
http://www.newegg.com/Product/Produc...&SID=u00000687
i5
2x4 gbs of DDR3 ram
7950
Here's a picture (and spaghetti): http://i.imgur.com/OS5YRVo.jpg
I don't need a pricey motherboard and don't really plan on overclocking, it just needs to be bigger so the pci slots aren't ridiculously close.
i5
2x4 gbs of DDR3 ram
7950
