Sound Blaster Live Drive & rounded cables
sofasloth
35
I bought a SB Live Platinum 5.1 with the Live Drive IR. I like to keep this system neat, so I use rounded cables. I hate the ribbon cable going between my SB and the Live Drive. I have heard some people say standard IDE cables will work, and some say they used rounded cables. I tried and had problems with the headphone jack on the drive not working with my rounded cable. It's a dual device cable, and I wonder if a single device cable would be better? Unfortunately, my single device cables have that damn blocking pin installed, and I can't get the darned thing out!
Is anyone else here using rounded cables with this SB combo???
Thanks
Ronstang
12,493
18
Drill out that blocking pin, round that sucker and give it a try! At least that way you won't mess up your original cable.
sofasloth
35
Duh, I should have thought about drilling. Thanks. Are you using rounded cables too with the live drive?
sofasloth
35
Didn't work. I guess that pin is needed. I moved the card to the last PCI slot so the ribbon cable would run at the bottom of the case and would be less obvious. I wish Creative Labs would sell a rounded cable for this thing!
