snoopy7548
- Jan 1, 2005
- 8,061
- 5,057
- 146
I wonder if gasoline would go bad if it were in something like a propane tank. Air and humidity trash gasoline. Keep it completely sealed it should last. Maybe not forever, but a long time.
Instructions? My neighbor has them already prepped.Ditch the pellet grill for rendering your neighbors and using the fat for fuel. Better smoke, makes everything taste like bacon.
You missed the workshop.Instructions? My neighbor has them already prepped.
I get alcohol free gas for my small engines. I have to drive to another state to get it, but imo it's worth it.Ultimately, yes - because what "gasoline" is referred to as today isn't the same as previous.
Our "gasoline" is 10% ethanol. Over time when sitting the ethanol begins to separate since they were previously blended.
This is why leaving gas in your yard tools (lawnmower, edger, etc..) is a big no-no and will screw it up.
But, but, but the government would never fuck up something like gas so the corn boys make billions, right?I get alcohol free gas for my small engines. I have to drive to another state to get it, but imo it's worth it.
I've got a station that's ~3 miles away...supposedly ethanol free.
Usually after the government screwed the pooch 1st then they get to come in and "fix" the problem.Government knows best
Listen to your government
It's a scary world out there
One way or another
Something will go wrong, I swear
Yea, corn gas pisses me off. All the alleged benefits are pretty dubious, while the detriments are well documented. It's socialism, and not even the good kind(the kind that benefits me :^P )..supposedly ethanol free.
I fill my tires with propane in case my gas tank hits empty.
What about snow tires?You need to inflate to whatever the max psi rating of the propane tank is, as it's calibrated for that type of propane. Make sure you use all season propane if using it for a car.
