Sony Universal Remote Control Help Needed
godspeedx
1,463
I've asked on the subject before, and I know a few people here have the Sony RM-AV3000 remote.
I just got this remote and it has supported all of my devices except my Sony Receiver. I've searched through every programmed code that the remote has and none of them work. Has anyone else had this problem?
CPA
30,322
4
Isn't the AV3000 a learning remote. You should be able to feed the Sony Receiver "signal" into the remote. You might lose a few functions or reassign functions, but it should work.
Which receiver, btw?
godspeedx
1,463
STR-K740P is the receiver.
I know that the AV3000 can learn remote control functions of devices that are already supported but I don't know how to learn the actual signal, or something.
Amused
57,548
20,267
Originally posted by: NutBucket
RTFM. I guarantee it will learn the codes....
unless its an RF remote
No, it's IR. You'll have to teach it each individual command. Not hard once you get the hang of it.
BTW, although the learning curve on that remote is high, once you get it programmed it is great. Learn how to prgram the macros and auto ons and you'll be amazed.
Amused
57,548
20,267
RTFM = read the fscking manual
RF = radio frequency
IR = Infra red
CPA
30,322
4
I had this same remote once (until the kid's broke it) and I didn't have to teach it each individual command, as long as the command was not in one of the generic setups. I distinctly remember facing the other controllers to the IR of the Sony, then pushing a couple of buttons and Voila!, the Sony now had most of the commands. Now, if I had to set up special functions (thumbs up and down on TIVO, let's say), then yes, those had to be set up individually.
Amused
57,548
20,267
Yes, some componants can be done that way. But I found that for many of mine, I had to teach each one individually. Also, for the bottom custom labels, I did those individually for each as well.
Also, I wanted some TV and tuner commands to work no matter what component I had selected, so I did those as well. Plus I customized many of the buttons.
NutBucket
27,181
649
Yeah, its a great remote. I love how it does EVERYTHING all my remotes do. Although, my big gripe is that its hard to use with one hand.
CPA
30,322
4
That, and I like to push buttons without looking. Generally when you get the feel of a remote you can change channels, pull up menus and guides without looking at the remote. With the 3000, the touchscreen forces you to look down to make sure you pressed the right part of the screen.
godspeedx
1,463
IR = Infra red
The manual doesn't address my problem.
It turns out it was a setting on the actual receiver that needed to be changed. It had to be switched from AV2 to AV1.
I found the solution here.
T2T III
IR = Infra red
Godspeed, Thank you! Thank you! All of the posters before you were replying just to increase their post count, but you provided the correct information that this person needed. I've owned a Sony ES receiver in the past and sure enough, this was an issue when programming another remote to use with it.
NutBucket
27,181
649
IR = Infra red
I stand by my comment; stupid sony.
HappyCracker
939
I gotta tell ya, that remote will not learn my NAD CD player remote for anything. I can still use it through the receiver, but not all the functions that remote comes with. Nevertheless, awesome remote
Amused
57,548
20,267
IR = Infra red
Bullsh!t. I sent him to that link to find help in the first place.
Amused
57,548
20,267
Did you try to teach the remote each individual command? It will learn ANY IR command. So even if it doesn't have a code for your entire CD player, you can train the remote to learn each individual button.
Amused
57,548
20,267
Yes, tried that. It just beeped at me like it didn't know how to learn that one.
That's odd. Which command was it? Was it only one command, or many of them, or all of them?
