Originally posted by: AsianriceX
Originally posted by: BuffBoyBradley
Okay, so I have my Triniton now. I'm running dual monitors. But when I just use my Trinitron, it will only do 1600 x 1200 @ 60. I want to hit at least this @ 85. But when I run it @ 85 it shakes. Does anyone else have this problem with theirs? Let me know, thanks.
Are you sure it'll support 85Hz at 1600? I tried looking for exact specs for it, but none would tell what the Max Refresh rate was at Max Res. Anyway, I had the same kind of problem with my Viewsonic. It's rated for 85Hz at 1600 and anything past 60Hz would cause the corners to shake. I then moved around my dual monitor setup because I didn't like it and retried 85Hz, worked perfectly. I think the problem had to do with the fact that the monitor was very close to the power outlet in the wall(yeah, it's kinda high up, I'm in a dorm room) and it didn't like being close to the 60Hz mains. You might wanna check that out.
Also, all but one of those vertical lines I complained about seem to have disappeared. Now there's only one in the center and it makes a perfect cross with the top damper wire. Still annoying as hell, but I hope it disappears like the other lines. I may have to exchange the monitor
