Someone is fvcking stealing my gasoline
EyeMWing
Banned
Jun 13, 2003
15,670
Originally posted by: Shawn
Good thing my gas door can only be opened from inside of the car.
Same deal with mine... And they havn't taken the hundreds of dollars of computer equipment and textbooks laying around in there. Just the gas.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Make a sparking cap.
This is like a child proof cap on med bottles. How it works is simple. Always push both bottons on each side of the cap. This will retract the flints and prevent them from engaging the outer ring. YOU do not want this to happen because if it does it will touch off fumes in filler neck. This will scare theif for sure. Your car will not blow up, that only happens in the movies.
sniperruff
11,644
i don't think people try to get into your car so they can steal your gas. at $3 a gallon it is expensive... but it's not $30/gallon. look into other reasons why you're losing gas.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Oh and the outside door that is released from inside is easily overcome with a leverage amplifier.
halik
25,696
Thursday morning, I filled up. Drove all of 120mi before having to fill up again this morning. That should've been a third of a tank. But the light was on and the needle was solidly on E. Thought it might've been a bunk gauge... But nope, the pump gladly deposited into the van a full tank.
And then after I filled up this morning... I'm now down to a half tank again... After 30 miles. Where in the fsck is it going?!
your o2 sensors are probably bad
Insane3D
19,446
Yep...decent size flat head and it's open no problem. It's just a little clip holding it closed...
Insane3D
19,446
O2 sensors go gradually, not all of a sudden. You don't go from 20MPG to 7MPG like that...
Shawn
32,236
53
there would be evidence however. I'm sure the paint would be scratched up.
redgtxdi
5,464
8
Can anybody say how much an 02 sensor can really contribute to bad MPG???
Obviously I think that 20 down to 7 something's wrong in Denmark but curious as to how many MPG a bad 02 sensor could actually contribute to............???????????????
MrDudeMan
15,069
94
gasoline doesnt evaporate VERY quickly and it leaves stains on aggregated concrete finish.
Rubycon
Madame President
Aug 10, 2005
17,768
485
there would be evidence however. I'm sure the paint would be scratched up.[/quote]
Well if you want to do this clean use a suction cup dent puller. They will probably rip the door off if you're careless though. LOL, that's actually hilarious!
MrDudeMan
15,069
94
use less question marks next time and i might answer
Insane3D
19,446
My Mustang GT was getting about 8 - 9MPG around town, and about 10MPG on the highway...
When I put on new headers and a SS X - Pipe, I changed both of mine out.
I now get 25MPG on the highway, and about 18-19MPG around town.
So, they can have a big effect, but they don't go all of a sudden. They start to switch slower and slower as they age, and most last about 60-75K before it's a good idea to change them.
redgtxdi
5,464
8
Insane,
Thanks!! Wow, that's a lot of MPG. I'd assume your pipes had somethin' to do with that too, but that's still quite a hop!!! Good 4U!
I might do the swap just to say I could measure & tell for sure myself.
