Originally posted by: zugzoog
Originally posted by: Eeezee
I tried it two different ways
The pattern method
1/9 = 0.1 repeating
2/9 = 0.2 repeating
3/9 = 0.3 repeating
9/9 = 0.9 repeating = 1
And then I tried it this way
3/9 = 0.3 repeating
6/9 = 0.6 repeating
3/9 + 6/9 = 0.3 repeating + 0.6 repeating
She still wouldn't believe me though! She keeps saying that since there is always something at the end of the string of numbers (despite being infinite) then it can be added together with something else to get 1 and is therefore not 1. I'm certain that you can't add anything to 0.9 repeating and get 1, but how can I prove this to her?
But 1/9=0.111... is no easier to see than 1=0.999...
Define 0.999...=sum from 1 to infinity of 9/(10^i)
(Forget about convergence for now which your friend might not understand.)
Let x=0.999...
ask what is 10x?
9.999...
What is 10x-9?
0.999...=x
So 10x-9=x, so x=1.
I find that 1/9=0.111... is actually very easy to see. All you need to do is elementary long division to see that you get an infinite string of 1s after the decimal. The human brain can pick up the pattern and, indeed, the human brain is correct in predicting that the number is infinitely long.
This is not your proof, you have made the assumption 1/9 = .11111...... exactly, let's test this assumption.
back to basic division. Sorry for the bad (or total lack of) formatting.
1/9 = 0.1 with 0.1 remainder.
= 0.11 with 0.01 remainder
= 0.111 with 0.001 remainder
= 0.1111 with 0.0001 remainder
= 0.11111 with 0.00001 remainder
= 0.111111 with 0.000001 remainder
rinse and repeat an infinite number of times
1/9 = 0.1111.... with an infinitesimally small remainder divided by 9.
Therefore 1/9 = .11111...... is an approximation.
The assumption does not hold up, this is not the proof.
Running throught the calculation again (I am calling the infinitesimally small addition to the number (to make it exact) "remainder", I am not sure of the mathematical nomenclature for such a concept);
1/9 = .111... + remainder/9
repeat 7 times
9/9 = .999... + remainder
therefore
9/9 = 1
footnote. If you say that the infinitesimally small remainder can be ignored then you are making the assumption that an infinitesimally small amount can be ignored to prove that an infinitesimally small difference = 0. This is circular reasoning.
