- Nov 10, 2004
- 428
- 0
- 0
I have a Lian-Li PC-60 Plus case with a rear 80mm fan... I was going to mod it to 92mm (by cutting the case), until someone suggested just using a fan adapter. I have a few questions about fan adapters... All the pics I see look like they mount into the stock 80mm holes then on the other side they have their own 92mm holes for your new 92mm fan. The part that looks a little confusing is the other end. Do they have a small duct that starts at 92mm and narrows down to 80mm, so the air flow will still be directed through your original 80mm hole? I am right in thinking they mount on the inside of the case? Does the air duct 'stick out' of the back of the PC? Are there ANY disadvantages in going with the adapter vs. cutting the case for a 92mm fan? I was originally wanting to go with a 120mm fan, but the case can't hold it (at least not flush against the back)... Perhaps the "ultimate" solution would be to cut out the case for a 92mm fan, then buy a 92mm to 120mm fan adapter. If the adapter will stick out (inside the case) an inch or so, I could mount a 120mm fan onto it...
-Thanks
-Thanks
