MagnusTheBrewer
IN MEMORIAM
You might want to check your local Home Depot. They rent FLIR cameras and you could use one to see if there's any massive heat loss from your home.
They make those that run on 240 amp?
Do you have a garage fridge or freezer?
Does your new place have:
- Halogen spotlights? Those itty bitty lights that were all the rage a few years back can use absurd amounts of power.
- A plasma TV? They use much more power than LCD.
You should get a Kill-A-Watt and measure your devices.
Yeah. I have a garage freezer--same one I had in the old place.
I find this to be a rather extraordinary claim, on what basis do you make it?The reason I ask, if a freezer/refrigerator is forced to run at or around freezing it actually becomes highly inefficient and may cause the compressor to run almost constantly.
Unfortunately it's a digital meter that only updates on in full kWh increments.
In February I used 1100 kWh with the garage heater set to 20 degrees while it was -20 outside.
In March I cranked the garage heater to its lowest setting--10 degrees--while it was 0 degrees outside. I used 1200 kWh.
why do you need to heat the garage? you understand garage is not insulated to the same standard as inside the house right? 20C?? yeah, your garage used up the electricity. Just turn off the breaker.
Are they taking readings or just estimating?
Seems like they may be estimating based off the past tenants usage?
Your house also got bigger. And from the sounds of it, you're in a really cold part of Canada that requires a block heater for your car? That's my guess on why you need the garage heated at all.
My garage is the common entry point for the city water for my row of townhouses. There's 8 units worth of exposed water piping in there... So not heating it is definitely not an option!
That's bullshit. Unless I'm misunderstanding, shouldn't you be paid to keep the garage warm so the pipes don't freeze?
