Hi everyone,
I recently added a 980Ti reference which I found in a good price in my system and paired it with my existing 980Ti G1 model in SLi.
In SLi mode I can o/c up to 230/7700, which somehow limits my G1 individual clocks by quite a good amount (G1 can do +310 on base core).
Not only that but boost clock which in SLi mode is around 1440-1450, due to heat issues with the reference model boost can get down to 1366-1380, even if I up the fan in reference model up to 100% in some heavily gpu utilized games. And it gets really loud as well, no comparison with the G1 model I have.
So I was thinking that maybe I could squeeze a little bit more performance from the reference model if I could get a better cooling solution for it..
Maybe I won't get higher clocks even if I power it more, but at least I could lower the temps/noise and keep the boost clock stable.
That is why I'm asking about your thoughts on this.. Should I go with an air cooling solution like an Accelero Extreme IV or an EVGA? Is there anything else in air that is worth my attention?
Or possibly go for an AIO solution? Any recommendations are welcome and thanks in advance for any help 🙂
