Right now, I got an ALX-800 with a thermaltake smart fan 2 cooling my mobile XP2400 (overclocked 300 mhz, although undervolted)
I recently got a rheobus for my fans since they are kinda lou.d I'm running 2 120s in the case, one is an alumin ball bearing fan, and the other is a thermaltake thunder blade. (1 is hooked up since I need a 3-4 pin molex adapter to use it on the rheobus)
Anyway, when I hook up the cpu fan to rheobus, the bios loads and everything, but then once I get to windows loading screen, the computer shuts down. If it is connected to the motherboard, then the computer starts. The motherboard btw is an abit NF-7s.
My guess is that since the motherboard doesnt detect a cpu fan at startup, it cuts off, thinking there is a problem.
Any suggestions to get this fixed?
Also, the 120 not hooked up to the rheobus has a 3 pin thing on it, but there is only a yellow cable, nothing else. When I hooked up that one cable to the rheobus, the fan wouldn't start. Im assuming that cable is for monitoring purposes, and not for power.
