Daedalus685
- Nov 12, 2009
- 1,386
- 1
- 0
I think they were not talking about a die, but about a module.
And a module doesn't include the uncore functionality, such as the L3 cache, which makes a big difference in terms of any die-area related issues.
There will also be multiple modules on a die, to further affect any die-area talks.
For a module, adding a second integer core, the 50% figure seems correct, and also it is meaningful. You show that the Bulldozer architecture significantly reduces die area per core, a very important metric in the current parallel climate.
For a full die, removing an integer core of every module, 5% may be correct, but what does that prove, really? It seems to be a completely random metric.
The latest info in the ANAND article and the press slides state 12% increased module size though... not 50%.
Certainly the 12% they state might simply be the "if I take it away I take off 12%" ignoring the larger uncore to support it... but that is all they are saying.. The new 'core' is substantially smaller than an old core, and adding a a dual core module is only 12% or so (certainly could be an inaccurate value...) larger than a single core would be assuming the same simple core design.
