solving sblive problem with asus A7V133/A7V133-C
StanTheMan
510
I don't know how many of you has sound problem using this board with the sblive card. I did.
My mobo is a7v133, the one with raid controller.
if i put my hard disk at the original ide controller, there will be sound crackling when i play mp3 and copy a file to hard disk. this does not occur if the hard disk is connected to the raid controller.
The cause of the problem is because ASUS defaulted its pci voltage to 3.45v, while the standard voltage is suppose to be 3.3v. As we know, the voltage is not always fix. 3.3 can go up to 3.4 or 3.25. When the voltage is set to 3,45, it can go as high as 3.56v !!!!
the solution of this problem is simply change the VIO jumper (located at the enge of the board, next to the ATX power connector, from jp2-3 (default, 3.45v) to jp1-2 (3.3v)
I don't know if anybody ever post this solution before, but anyway, I hope that helps
Bartman39
Elite Member | For Sale/Trade
Jul 4, 2000
8,867
51
Good observation but I think it also has something to do with placement of the SB live card (in which PCI slot...)
Reason... look at the "Gang"
StanTheMan
510
I put mine in the 2nd pci slot. I let the first one empty to give more space to my graphic card :p
Maggotry
2,074
On the A7V133, PCI slot #2 shares IRQ with the RAID controller. Not necessarily a problem, just an observation. When I had this board in Grendel (see my sig), I HAD to run the DRAM voltage at the default level. Dropping the voltage to 3.3V caused the system to crash all the time with .dll faults. Creative recommends putting their cards in PCI slot #3. I don't know why, that's just what they've told me on several different occaisions. Whatever.
