(Solved)Poor Performance, Whats the problem?
CrowDog
1,709
8
It's been a long time since I've been heavily into computers. Last computer I built had an Athlon XP 1700+ and Radeon 8500. So needless to say I'm out of the loop. I'm trying to play SW:ToR and I'm getting really poor FPS in populated areas sometimes dropping under 5fps. The system I have now is a Gateway lx6200-01 http://www.newegg.com/Product/Product.aspx?Item=N82E16883113077.
I purchased an Asus EAH6850 off Craigslist for $100 thinking it would fix my problem. Its alot better but still pretty poor fps. So my question is there anything I can do with this system here to improve performance? If not is there anything I can still use out of it when building a new one? Does someone have any recommendations for my cheapest possible fix to my frame rate problem?
thank you for your time!
fralexandr
2,295
232
www.flickr.com
http://www.tomshardware.com/reviews/star-wars-gaming-tests-review,3087-7.html
do you have transparency AA on? you should disable it
overclock the phenom. you might be able to reach 2.6GHz, which might be enough (3.0 would be optimal, but i doubt that's possible on the phenom I as google only shows 2.4-2.7GHz)
it might not be possible with the gateway though, and you might need to use a software to overclock
otherwise you'll probably need a new CPU... the phenom II 940(AM2+) will work in the gateway 6200, but i'm not sure if the am3 ones will (there are a few people claiming to have socket AM3 cpus, so it might work)
http://www.tomshardware.com/reviews/star-wars-gaming-tests-review,3087-8.html
what screen res are you running?
maybe try doing this
http://www.swtor.com/community/showthread.php?t=114264
mfenn
22,400
www.mfenn.com
A 2.2Ghz original Phenom isn't doing you any favors in a fairly CPU-intensive game like SWTOR. If you can find a Socket AM2 quad for cheap, I'd try plugging that in. Otherwise, a G620, H61 mobo, and 8GB of DDR3 shouldn't run you more than $160 or so.
DominionSeraph
8,386
32
5FPS sounds ridiculous for a 2.2GHz quad with 6850 in a MMORPG, though; even if it is a Phenom 1. I mean, the difference between 1 and II is only 10-20%. Heck, Anand tested only a 3% difference in Farcry 2. So if Tom's is getting 48FPS/39 minimum on a 2GHz Phenom II X4 it seems to me that something's really out of whack for his 2.2GHz Phenom 1 to be having such difficulties.
Nativegamer, just figure it out. There's enough tools out there so run your own diagnostics. Computers aren't rocket science.
CrowDog
1,709
8
Thank You! and after further homework,your right something was "out of whack". Something called The Phenom 9500 & 9600 TLB FiX . This more than doubled my fps and Im now seeing fps in the 45-60 range:p I found the info here http://forums.riftgame.com/rift-gen...569-improve-fps-phenom-9500-9600-tlb-fix.html .
