SOLVED- How to switch from single to multi cpu Win XP Pro?
Wiz
6,459
16
One of my systems running Seti had a mini meltdown so I had to do a repair.
Now it only sees one cpu, this is a P4 HT MACHINE AND ht is enabled in bios.
Is there some way to change it so it sees 2 'cpu's?
Soggysocks
1,250
1st what did you fix? 2nd do a cntl-alt-del and check your performance tab and see if it shows 2 cpus. 3rd have you gone to your hardware manager and scanned for hardware changes?
Wiz
6,459
16
its definitly running the single proc HAL
I will try the scan.
Did an Upgrade reinstall with my slipstreamed SP2 XP Pro, all my old apps are still intact but it defaulted to the single cpu version. I've reinstalled SP3 and the MS updates.
RaySun2Be
16,565
If the scan doesn't work, try this:
Installing Support for Multiple CPUs
Click Start, point to Settings, point to Control Panel, and then click System.
Click the Hardware tab, and then click Device Manager.
Double-click to expand the Computer branch. Note the type of support that you currently have.
Double-click the computer type that is listed under the Computer branch, click the Drivers tab, click Update Driver, and then click Next.
Click Display a list of known drivers for this device, and then click Show all hardware of this device class.
Click the appropriate computer type (do not change from non-ACPI to ACPI computer types), click Next, and then click Finish.
HAL.......................Description
ACPI MultiProc........Use for a multiple-processor ACPI computer
ACPI UniProc..........Use for a ACPI multiple-processor board but with a single processor installed
Advanced...............Use for a single processor motherboard with single Configuration processor ACPI computer Power Interface PC
Compaq Systempro.....Use for a Compaq Systempro computer
MPS Uniprocessor PC...Use on non-ACPI computers dual processor motherboard with a single processor installed
MPS Multiproc PC........Non-ACPI computers with a dual processor running
Standard PC..............Any Standard PC, non-ACPI, or non-MPS. Could be a 386, 486, Pentium, Pentium II, or Pentium III
Standard PC with C-Step i486
Wiz
6,459
16
Thanks, I already tried that - first thing I did was search the MS Knowledgebase and found that method. Trouble is only the ACPI I am currently using and Standard Computer appear in the list.
I'm pretty sure I remember doing this before, but it was long ago. I believe I had a thread on here about it at that time. I'll search the archive and see if its still here.
Wiz
6,459
16
Interesting...
I went into bios & disabled Hyperthreading, then restarted and scanned for changes.
Then I restarted and went into bios and enabled hyperthreading and restarted and then scanned for hardware changes.
No difference under Computer > Advanced Configuration... (ACPI) Computer but...
Under Processors I now have two Intel Pentium 4 CPU 3.00GHZ listed - how about that? Weird huh? Task manager still only shows one cpu.
Wiz
6,459
16
It ran, it said "One or more problems were detected".
It didn't say if it did anything about them.
(oh - and no changes, still running like a single cpu)
Wiz
6,459
16
I ran the repair console again and specified /p /r and it said it repaired something.
Still no joy.
I reran the setup and did an upgrade reinstall and this time it installed the right HAL.
Assimilator1
24,153
517
Out of curosity I had a look at mine XP, (I've got a single C2 quad) I have 'ACPI Multiprocessor PC' in the device manager. Different rule for quads??
