Solved Amd Althon 1700+ Help Solved Solved Solved
BmXStuD
1,474
And i think newegg is giving "B's" away now i got a
AXDA1700DUT3C 9468967280714
JIUHB 0312VPMW
OLD DEAD ONE IS
AXDA1700DUT3C
JIUHB 0311XPMW @ 1999AMD
Theres a sticker on cpu w/ like a serial # shouldnt i remove that b/c it will burn. MY old cpu didnt have a sticker.
Actaeon
8,657
20
Cool, hurry and install it!
Let us know the results :)
As far as the sticker, is on the actual CPU core? Or on the packaging?
BmXStuD
1,474
Its on the cpu its self which is the green part between the two black soft things that the hsf lays on.
minendo
35,560
22
The sticker will be fine where it is.
pillage2001
14,038
It won't burn and keep it there. If anything happens, newegg might need it to id the chip they sold you.
BmXStuD
1,474
PROBLEM! I got it @ 1.97ghz but it still says 1700+ why.
http://pics.bbzzdd.com/users/s4rge/dd.JPG
Shoudlnt it boot as like xp 2200+ ?
(im overclocking so going down is the speed @ now. So the last speed listed)
Its at 2038.5mhz
2090.1mhz (fsb 154.1)
now and stable still says 1700+ though.
ram is @ 302mhz =ddr2100
volt 1.632
BmXStuD
1,474
Originally posted by: zodder
See if there is a a BIOS upgrade for your board which recognizes higher speed cpus.
Ya i have it @ the latest bios which is 1012 for asus a7v8x.
BmXStuD
1,474
I took a mirc system stats and this hmm whyz??
(CPU) 1-AMD Athlon? XP 1700+, 2079MHz, 256KB (41% Load) .:. (RAM) usage: 168/512MB (32.81%) .:. (GFX) NVIDIA GeForce4 MX 440, (Display) 1024x768/32bit/60Hz
(OS) Windows XP Professional (5.1 - 2600), (installed for) 6d 9h 57m, (uptime) 15m 51s .:. (HDDs) 13.2G/24.6G(53.6%) free
Anonemous
7,361
I'm guessin it has to do something with the FSB (whichever it is closest to 100/133/166/200, so if you are somewhere in between I guess round off) or the Multiplier because when I upped the multiplier from 12.5 to 13 with an fsb of 180 i jumped from a respective (2600+ rating to a 2700+ rating in the bios). 13 to 13.5 resulted in a 2800+ rating in the bios. Use Sisoft Sandra and to bench the cpu and they'll give you a better estimated AMD PR rating.
BmXStuD
1,474
K im bench soon i will post results.
this ? http://pics.bbzzdd.com/users/s4rge/dsadd.JPG
I know its running @ a 2600+ speed but w/ 266 ram.
John
Moderator Emeritus<br>Elite Member
4
BmXStuD, please stop being impatient, and give people some time to reply to your thread. Unless this is a life or death issue you should not need immediate assistance.
BmXStuD
1,474
Alrighty just alittle excited to have a cpu over 2ghz. Ya this one small little program is causing all of this ;-(.
Spyro
3,366
Ehhhh??? What???? Get a new program then!
BmXStuD
1,474
Not just a program its post/bios screen also. CPU is over 2ghz but shows 1700+ everywhere or unkown cpu in 3dmakr points.
BmXStuD
1,474
Sry guys im dumb. I know now that "overclocking will not change the cpu specification if that's your misconception" and not what i thought man. That was easy answer mirc comes in handle some times :/ i see. Well again sry peeps for all the crying and crap and the post in general hw.
