Solve this flash puzzle
Originally posted by: TuxDave
Originally posted by: TechnoPro
Originally posted by: DanTMWTMP
http://www.foon.co.uk/farcade/hapland/
I already solved it. I have pics to prove it.
((pics may show possible spoiler to solve the pozzle))
YES! i did it!!!
The end!!
Awesome game, thanks!
I beat it but my end game looked different than your screenshot.
Yeah... I didn't even have anyone standing on the top.
Nor did I. Although I could have launched a man up there for kicks...
Originally posted by: pkananen
someone please help us who should have been in bed long ago
SPOILERS!!
1) open the grey lid, press the yellow arrow a man will pop out
2) fire the cannon set in the "low"position agaist the wooden bar (it will become horizontal
3)open the small window on the bottom left, click on the red arrow and set it to RIGHT
4)set the cannon in the HIGH position and fire against the Bell (the bottom left door will open)
5)set the cannon in the LOW position, fire the first bomb and QUICKLY press on the wooden bar while the bomb is still in mid-air, you will get it and make it explode without causing damage. Do the same procedure for the second bomb.
6)with the cannon in the LOW position fire the blu keycard. the man in the prison will use it to open the door.
Steve Yokoyama says:
7)fire the empty cannon, the man will be dropped in the cannon itself. press the yellow arrow to make a new man appear.
8)set the cannon to HIGH position and fire the man near the Bell. BE CAREFUL, you have to press the spiked lever near the bell to make it lower for a second, just the time for the man to pass safely. So press the spiked lever when the flying man is approaching.
9)click on the man that is now under the bell, it will move the wooden structure.
10)click the bell for 3 times, the paper bullet will make the landmine explode, then you can click on the door on the bottom left and the man will pop out and enter the new building.
11)LAST MOVE: click on the man that was in prison, a dog will drop from a crate, WHEN THE DOG HITS THE GROUND, quickly press on the lighted window above the prison. A piece of stone will fall killing the dog.
SPOILERS!!
alternate: in step four, click on the spiked lever thingy as the rock hits the bell....it wll eliminate you having to click on the spiked lever in step 8...
SPOILERS!!
I didn't use that many steps at all... hmmm
SPOILERS!!
In Step 4, while the rock hit the bell.. change the position of the swing so it lower the pointy end on the right. 2 possible will happen, the swing will knock the falling rock off the clift and land on the mine. Or the rock just sits. Then you can do step 8 easily and afte you launch the man onto the clift, he will push the position of the bell then click the bell 3 times to drop it and it will knoc the rock onto the bomb.
I just got it... the damn timing aspect is really annoying with the dog at the end... i kept missing the bastard lol...
fun but too short =)
Just click the window when the black exclamation mark appears above the man's head.
This game could use some minor usability issues. For instance, an "undo" button and the fade-in when you reset it wastes too much time.
SPOILERS!!
This method makes the most sense. The see-saw rock trick is too hard to do reliably.
