Solution to my desk problem: Fix my current desk.
TridenT
16,800
45
Structural engineers, I demand your expertise. I need to figure out how to stop the shake in this damn desk while using it.
It shakes side to side and it's really fucking annoying!
I don't know what would cure it. Maybe thin bars that go in between the two stands that are locked in place with nuts on threaded ends? I don't know.
Video of shitdesk: http://www.youtube.com/watch?v=AsR2AqHhGYU
TridenT
16,800
45
Why a new thread on this so soon? You already have a desk thread.
That's about great desks. This is a thread about fixing my desk.
I'm going to just try to fix this piece of shit before I go spending $100+ on a new desk.
Ronstang
12,493
18
You need an X brace across the back. Make it out of some 1/4'' rod or something similar so it looks like it belongs after you paint it black.
TridenT
16,800
45
That's definitely not going to be easy since there's nothing I could easily attach the brace to. :hmm:
x-alki
1,353
How much room is there between the glass on the legs and the metal legs? If there is enough room you could drill a hole in the metal and use a threaded rod to form a cross brace.
coxmaster
3,017
Honestly I would just spend 50$ a get a decent cheap desk. Thats what I did and its working just fine.
SKORPI0
18,492
2,424
Attach the keyboard drawer, like it was supposed to. That should fix it. :hmm:
BoomerD
66,357
14,770
If that's indeed his desk, and it does look like the same one, putting the keyboard drawer in place would go a long way towards stabilizing the desk...
Also, are all the connections on the back good and tight?
(the OP might need to find a man to check them)
MotF Bane
60,801
10
This is not a question for structural engineers. This is a question for anyone with a functioning brain. A little logic, some spatial reason, a bit of common sense, and you're all set.
1) Get some tools, and make sure the current connections are solid.
2) Put in the keyboard tray. It will increase the stability.
Also, where do you do your homework? Studying? Reading? On the corner of that desk, perhaps? That brings me to #3.
3) Build a new desk.
Dec 10, 2005
28,967
14,290
Tighten the screws on any cross beams. Install a new crossbeam where the keyboard tray used to sit if necessary.
TridenT
16,800
45
Everything is tight as it can be. The addition of new hardware is going to be what I'll have to do. Any ideas where to get proper beams?
