Solution to my desk problem: Fix my current desk.
Leros
21,867
7
I had that desk for a few years. It was a wobbly piece of crap and I eventually got rid of it.
TridenT
16,800
45
:mad: This does not make me happy.
You think it's fixable? Maybe if I have two very even file cabinets then I can put this on top of them after I drill a perfect fit circle in both of them.
Capt Caveman
34,543
651
Simplest thing to try would be attaching some brackets like these
to the legs and the back support to hopefully stiffen the frame.
iGas
6,240
Use the below, with rebars and pour concrete in the empty blocks to make a solid block underneath your desk.
images
TridenT
16,800
45
Now you know where to spend your $1000...at a good furniture store...buy yourself a quality desk instead of some POS like the one you have.
I prefer other things. I can stand to not have expensive furniture while having other things that I prefer to have. I'm not going to have anything I own except a few things in less than 4 years when I move across country...
SuperSix
Buy electrical conduit, long enough to make a cross-brace, hammer the ends flat, mark spots, spray paint said conduit flt black, drill holes and bolt them in.
Slightly bend each in the middle where they will cross.
fatpat268
5,853
34,334
This is going to be tricky but here it goes...
1) Push the back of the desk up against the wall behind the desk
2) Move that crap to the right of the desk out of the way
3) Push the desk up against the wall to the right
4) Double check that the back of the desk is still against the wall
5) Pick up and throw away the chip bag you slob
6) Go out and get some sun
Leros
21,867
7
Probably. The glass is surface is rigid. It just has that cheap sheet metal frame that wobbles. Mine mostly wobbled side-to-side and there are only two real joints that are flexing. Shouldn't be too hard to stop the wobble.
