Originally posted by: ChicagoPCGuy
Although I love Soltek, I think they made some serious errors with this board.
1. They are using a 20-pin ATX power connector!!!!! What about the Radeon X800XL that does not have the extra power connector on it? Without the extra juice provided by the 24 pin connector, I worry.
2. They went and used the non-Ultra version of the chipset.
Both of these will keep me from ever buying this board.
I feel the same way ChicagoPCGuy ! I REALLY wanted to buy this board but for the reasons you stated it seems like a poor choice. Will you (or any else) take a look at my thread over here and tell me what you think??? I have all the details worked out now except for the MOBO decision. I'm pretty sure that the Asus Radeon X700 is the way to go with the videocard ! Dont' you agree ???
Thanks,
Greg
Originally posted by: Macro2
RE:"They are using a 20-pin ATX power connector"
Good, I have a 20 pin power supply. Isn't this 24 pin thing something to do with Intel BTX anyway?
I agree about 3 PCI slots instead of 2. Should have sacrificed one of the PCI-X1 slots.
OTOH, the only thing I see for a PCI slot is a high end sound card. I assume the rest of the posibilities will fit in the PCI-1 slot.
There is onboard LAN so don't need a slot for that.
I'll use this with an Antec smartpower 350.
A high end video card is not an issue for me. Maybe a 6600GT at best but probably a 6200TC.
Yes, I think.
Now, here is my own opinion ..
Right now, I would not care about having a 20 or 24 pins header on my motherboard right now.
If the x800xl would have need more power than the PCIe bus standard allows, then ATI would have include a connector on their board, as they did with other card. If you have a good PSU, it will power up the board and the video card without problems. But a weak PSU would not even start the whole thing. If you have a cheap PSU, and your system do not power up, who are you going to blame? Soltek or any others motherboard manufacturer that still use the 20 pins ATX header? Or ATI because they did not include the additionnal connector? Why not you about being so cheap about the most important component for modern system?
Every motherboard had to follow standards for buses. That assure stability in design. Can you imagine the mess if there was no such guidelines... I'm sure that ATI did test their card with standard PCIe bus and they found it compliant. The card doesnt need extra power. What the PCIe bus provide is sufficient. Bless the new Radeon core for that.
Not being the Ultra once concerns me, but after I realized that all that I would have more is options that I will not utilise now, then I dont care. There is no SATA2 HDD now and NCQ is not really a performance edge that even worth being mentionning. And about the firewall.. well, yeah. Still buggy in some area and incompatible with some router. So, no a big miss for me.
The only thing I dont like about this board is that it has only 2 PCI slots. I really need at least 3.
But I know that some people buy big number, even if there is no or only very small improvement, 939 over 754, dual channel vs single channel, sata2 vs sata1, 24 pins vs 20 pins, ...
Originally posted by: cpush
any via k8t90 boards with a 24pin connector besides gigabyte, albatron, and asus?
lame. I'm not liking the nforce4 boards at the moment and want to upgrade within the month. Was really leaning toward the Soltek boards but with the lack of the 24 pin connector I have to refrain.
nah man I need to rock out the x800xl, and dont feel like throwing down 100 extra dollars for one with a connector on it when I could spend a bit more for a different motherboard. Its just that I havent found an nf4/nf4ultra board that attracts me. So now Im kind of lost. I would go with the soltek but then I have to make accomodations for my psu (different connector) AND videocard. Which shouldn't be necessary and seems rather bothersome. Dunno anymore..
Originally posted by: ChineseDemocracyGNR
...The vanilla nForce4 is only missing SATAII and ActiveArmor support compared to the Ultra. It does have Gigabit. In addition to SATAII and ActiveArmor the SLI chipset supports SLI...
Hi Greg. Yeah, for what you want to do a X700 is totally more than fine. Definitely get PCI-E! As for CPU/Mobo:
While it is true that P4 systems with HT do audio encoding somewhat faster than the A64, they totally suck for gaming. I mean SUCK. Now, with a 939 mobo (I recommend a Winchester core A64 3000+ for you right now for a small $146 PIB) you can go with a dual-core x2 Athlon 64 in a few months and they will totally annihilate the P4 in both gaming AND audio encoding and just about everything else. Even the lower end x2 A64 CPU's will trounce the P4 single or dual core CPU's Intel is releasing. If you should lose your sanity and go Intel, stay away from Prescott unless you want to add a heater to your house, in which case it will serve this purpose (along with the others you stated) quite well. The Prescott core is a slow and overheated dud. The Northwood is the better core, but then you will be limited to Socket 478, and there is NO FUTURE there.
Definitely go A64 939, PCI-E, nForce4 Ultra. I recommend the EPoX 9NPA+ Ultra. It is relatively inexpensive, trouble free, and has a good name. Shy away from SLI. Most SLI boards are:
1. Pricey
2. Not what you are looking for
3. Quirky
Take care.
...Are there any reviews yet?
...the Ultra...the firewall.. well, yeah. Still buggy in some area and incompatible with some router. So, no a big miss for me....
This is basically the nf4 version of the KT890Pro isnt it
I suggest you look over at X-Bit Labs and check out their PSU article. Sad to say, but a 20-pin power connector is right on the edge of not being good enough when you are using a PCI-E video card like the X800XL without a power connector on it. You definitely better have a high quality PSU. Apparently a 20 pin connector is left with ONE PIN to provide power to the PCI-E bus as opposed to the additional pins a 24 pin connector provides, so it is not just a BTX thing. That pin can actually BURN. Here is the link: http://www.xbitlabs.com/articles/other/display/atx-psu.html
I think I can pretty much safely say Soltek made a big mistake, IMHO.
...I got the EPoX 9NPA+ Ultra and have been VERY happy with it. The board rocks. Expensive PSU, the mobo, A64 3500+, and a GeForce 6800GT, and now flat broke. But, I don't regret it.
