Originally posted by: futuristicmonkey
Buy a used mini-fridge.
Open the door.
Coolness 🙂
That will make the room warmer, because of the power wasted by the fridge.
Open the door.
Coolness 🙂
Originally posted by: cker
Oh, and regarding dumping AC 'radiators' into the air -- please don't do that. If you want to use something like those copper assemblies, ask a local AC shop if you can raid their trash. They may charge you gor the privelege, though, due to copper's high scrap value. Some people have good luck using the old heat exchangers from the back of refrigerators, but they're no exactly tiny. They also can contain coolants, though. They normally are required to reclaim old ozone-depleting coolants from such systems and therefore you should have a better shot at not fouling the air. Besides, Freon and other coolant compounds are REALLY NOT A GOOD IDEA TO INHALE. Freon itself is non-toxic but (a) it's banned and (b) other coolants may not be -- please be careful not to inhale coolants. I didn't go into Ammonia coolers partly because of that -- an ammonia relase in an enclosed room like a dorm room would pretty much certainly kill anyone caught in it.
Freon toxicity
http://www.envirotools.org/factsheets/contaminants/Freon113.shtml
Originally posted by: Jeff7
Where might be a good place to check? Online stores that sell hardcore PC cooling stuff should have smallish radiators, but where's a good source of really good radiators?
Is it possible to take an AC/refrigerator/dehumidifier/whatever somewhere and just have them empty out the coolant, and then let you keep the rest of it for parts?
I failed to even see the part that the OP wants to keep his PC cool. If that's the only concern, either do water cooling, or get one of those expensive mini-AC's for the PC. They'll use less power than a traditional large air conditioner, or so I'd imagine. Something like this.You're still talking about dumping the heat from the PC into the room's ambient environment, though. If the heat's really bad, then I don't see any marathon gaming sessions in the heat of the day. Obvious: Putting your radiator in the sunbeam will not help. Not meaning to be an ass, but I've seen people totally miss that about a heat exchanger. If the radiator is picking up radiant heat from an outside source, then it will work opposite of how you want -- it'll turn into a heat ABSORBER.
But then there's still the problem of how to get just the radiator without releasing all the coolant into the atmosphere. That Thermaltake radiator I linked to looks good. Copper and aluminum, just like you'd find in an air conditioner, so it won't rust.You could probably scavenge any of the appliances you mentioned (AC, fridge, et c) and get a radiator.
