us3rnotfound
I have the Klipsch Promedia Ultra 5.1 speakers connected through Monster Cable, and I was thinking, could I achieve more crisp sound quality if I soldered the ends of said cable?
Thanks.
Thanks.
Originally posted by: YOyoYOhowsDAjello
Ditch the Promedias?
Don't invest anymore in them. It's not going to change the fact that they're made out of plastic.
Prime candidate for Swan M200s
Originally posted by: shortylickens
You have a Klipsch Promedia ULTRA connected with monster cable, AND YOU WANT BETTER SOUND?!?!?!?
Yes, I looked at those for a long time. Are those up to par with just plain, simple, prestine clarity? Is it worth "downgrading" from a 5.1 setup to a 2.0?
Thanks for all your great suggestions. I am looking for the most economical way to turn my listening experience (mostly music, yes I do game a lot) from crap to pure audio bliss.
Remember, most economical, and so far, it's looking like the Swans M200 set is the answer.
Yes that does look like a nice little project, but I'll do what you suggested, I'll go talk to a local HT dealer, then check with ribbon13 sometime.
Any good guides online that you know of for building an amp? I've built my own laptop, so I think I can tackle this project.
Thanks.
