Soldering iron help.
highland145
43,973
6,340
Bought the kid a Ramsey escape robot kit. Have to solder the resisters, caps, etc to the circuit board. My Weller 8200 isn't going to do the job. Looking on Amazon, there are varying wattages for the small tipped irons. Any ideas what the appropriate watts for this is? Suggestions on other brands are welcome too.
Thanks.
effowe
6,012
18
When working with electronic components, I don't go above 15W. You can get adjustable wattage irons as well.
bobdole369
4,504
http://www.radioshack.com/product/in...odsInSession=1
or
and replace with a conical tip. I hate chisel tips myself. 15W should be plenty, but nice to have the 30W option. Looks all through hole stuff so it'll be nice and easy.
This is the best solder for most instances IMHO. (That is the best available at radio shack) - no extra flux is typically needed. I like using a brush with 99% isopropyl to clean off the burned rosin after soldering.
bobdole369
4,504
If you're going to be doing any regular soldering, I'd recommend spending a little extra. Get the Hakko FX-888. To your door for $81... http://www.kimcodistributing.com/store/item.asp?ITEM_ID=2943&DEPARTMENT_ID=439
It's not an absolute necessity, but it sure makes soldering more pleasant.
Hakko makes real, real, REAL good shit. We used their line in production at an electronics manufacturer. Excellent performance, on 8 hours a day non-stop soldering work. Loved it, and the ones I linked before aren't "bad", they are just not as well made as Hakko.
dwell
pics?
I use 15W for my smaller electronics work. Harder to burn up a cap or transistor with lower wattage.
highland145
43,973
6,340
If I knew he'd love it and want to do more, I'd go with the Hakko (and may still). If it's a one and done the RS are fine. Thanks again.
Edit: The Hakko is temp scaled. How does that translate to watts? Not wanting to burn up the components.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Temp control is what you want on a workstation. Poor soldering technique, not watts is what burns up sensitive components. ;)
Rubycon
Madame President
Aug 10, 2005
17,768
485
It's always good to have spare (extras) on hand.
Also practice makes perfect - or almost. ;)
Find some old boards/parts to learn on. Definitely helps.
dwell
pics?
I've never fried a part but I am usually working with vintage or hard to find parts like germanium transistors and diodes or out-of-manufacture ICs and would rather not tempt fate. Then again I usually socket those parts to minimize the risk in the first place.
dud
7,635
73
Thanks.
Was this a present for your kid ... for you ... or for both?
I remember my last soldering project years ago. My Dad came over and was enthralled as I integrated all of the components onto the board. Those were the days ...
highland145
43,973
6,340
Mostly for him. Trying to get him interested in orther things. We took apart some dead electronics a couple of months back and he couldn't believe how it worked. It was like magic to him. And the little I remembered from electronics classes 25 years ago was embarrassing.
Gibson486
18,378
I got a metcal in 06. Have not looked back since.
Also, practice, practice, practice. On my 2nd internship, I worked with a guy who would not let me leave until i successfully soldered a surface mount resistor. took me an hour and a few resistors to do it.
Rubycon
Madame President
Aug 10, 2005
17,768
485
LOL yeah Metcal is the Rolls Royce there. Not sure the OP has that (budget) in mind! ;)
