Yea, because people like being thrown back into the 1980s. Who needs tab-completion, real package management, etc? And the fact that Sun is open sourcing Solaris tells me that they're beginning to realize that Linux is better than their software in almost every way and they're grasping at straws to generate buzz again. I have no doubts that there is still some kernel-level things that Solaris and AIX beat Linux at, but from a user/admin standpoint I'll choose Linux any day.
"back into the 1980s"?
You think AIX and Solaris have been staying in the 80s?
tab-completion?
It's a shell feature you know?
I am using ksh on all systems anyway (for me it's much easier to reach Esc than the Up_Arrow, so I am staying away from bash).
Real package management?
You acutally mean easy package management right? which takes care of the dependencies, like
www.blastwave.org ?
The AIX/Solaris package management are very real to me.
Some kernel-level things?
So you don't care much of kernel-level things, that's perfectly fine. The point is a normal user has no need to care about it, it should just works.
But then I don't think you care about RAS either right? What's the point RAS? Linux runs stable for years and if anything goes wrong, you have the source code and you can find the bug and fix it, right?
Ok, let's stick with the things you do care: usability.
Tell me something you find so unique about Linux that Solaris doesn't have ( AIX is not designed for home/PC users, so let's leave it out).
I'll start with some "OS reviewer"'s favorate:
1. Install and boot
2. Support of wide range of hardware
Before we comment on that two (it's getting late), anything else you want to add?
You said using Solaris/AIX is like going back to 80s, so there has to be something else ... how many times you have to install and boot an *nix anyway, right?
BTW, Let's don't get into CDDL/BSD v.s. GPL issue, ok?
T
