Solaris vs Ubuntu
DasFox
4,668
46
Well of course they are not 100% the same, but they live in the same world of computing, use the same tools, desktops, software etc.... When you try to compare them to the likes of Windows, now there is a difference greater then what they are from each other. ;)
Now you know what would be interesting to see, I'd bet that the differences between them is less then 25%, I'd love to see a statistical difference on what percentage level they vary.
I wonder if anyone has actually compared them in this regard?
ALOHA
n0cmonkey
42,936
ALOHA
Differences how? Differences between the various commands?
DasFox
4,668
46
ALOHA
No the overall differences of the entire OS.
jhu
11,918
9
come to think of it, what defining characteristics make an operating system "unix" or "unix-like"?
drag
8,708
Mostly nowadays it's resemblance. X Windows for GUI. Unix shell. Unix directory structure. Unix utilties.
I've had people argue that in that case Windows is Unix-like because of the POSIX compatability built into the NT kernel and it's ability to present the file system as a Unix-like file system through things like SFU and such.
There is a certain 'Unix' philosophy to designed software and it shows in a end product.
Things that are highly valued are things like portable software. A lot of Linux desktop could be improved quickly, but people value portability of everything so they have to work on getting it 'right'. They want stuff to work well on not only Linux, but OpenBSD, FreeBSD, Solaris, and often OS X and Windows.
That's just a example.
Other things like following a similar directory tree system with root and mounted directories and such. Also things like device files you can interact with.
Things like being able to pipe data from applications to another is Unix-Like.
Another example of something Unix-like is having strong differentials between layers of software and high level of abstraction to keep things seperated.
For instance in Linux I can have my operating system running on a harddrives. I can have my operating system running on a remote server over a network...
Or I can do things like having my operating system running in a chroot environment in another operating system with it's file system being a combination of a compressed read-only file system with directory taken out of another file system running the 'parent' operating system overlaid over it saving the differences. All of which is booted up over a network running on a diskless desktop.
It doesn't matter. As long as the file system does it's job and is relatively posix compliant I can be doing anything. There is no realy oddball dependancies between system layers unless your dealing with very specialized software.
TCP/IP protocol stack and the OSI protocol layers model is something that is very Unix-like in it's approach. Each having a seperate layer
And the 'everything is a file' thing.
And the text files for configuration.
Another Unix-ism is that text is the universal data storage medium. Out of that we have XML, which is sort of crappy if not used correctly, but is essenctially just plain text file with rules on formatting.
Nowadays it's not nearly as odd as it was at other points. A lot of Unix-isms is taken for granted.
For instance the user group model with read/write/execute permissions is something that Windows adopted with a few modifications. That sort of concept originates from Unix systems.
Another example of Windows being Unix like is that the DOS command line is very Unix-like in a lot of ways.
Not suprisingly the first operating system that Microsoft developed and sold was Xenix, which is a Unix operating system based on AT&T code. Ironicly a lot of the development worked was subcontracted out to SCO by Microsoft.
So talking about what makes something 'Unix'-like doesn't make so much sense because people don't considure Windows Unix or Unix-like, but it borrowed a great deal of ideas and basic concepts from Unix. It doesn't make sense often because you can go 'this, this, and this' is what makes something 'unix' but Windows has all that stuff also.
Microsoft, as I understand it, even used Unix for it's sole development envioronment all the way up until Windows 3.11 came out.
But of course Microsoft lacks the highly structured development stucture, the device file stuff, the disctinct software layers, and such that Unix-like systems will typically have.
Another example is Unix is something that is generally realy open. Most aspects of the system is open and even with propriatory systems it's common for admins to deal with kernel manipulations. Originally AT&T Unix gave away source code. There would be books you could buy which was nothing by the source code for Unix. They gave it away no-cost to various educational institutions and businesses and such.
The difference between "UNIX proper" vs "Unix-like" would be code heritage.
FreeBSD is UNIX. Solaris is UNIX. Linux is NOT UNIX.
Solaris is based on system-V originated code and BSD originated code via SunOS. FreeBSD a decendant of original BSD Unix which was modified AT&T code. Although I would expect that from Solaris and BSD almost all traces of AT&T code and other code developed by companies is completely gone at this point the design of the software and operating system kernels is still going to show it.
Unix is so basic to most everything we deal with in modern computing environment from everything to how the WWW and the Internet works to how command line works in operating systems and abstraction layers and such. The best way to see something is Unix-like is by seeing something that is very much not like Unix.
Fort instance I took a class for a while for OS/400 operating system and I work with a VSE/ESA operating system at my job. NOT UNIX LIKE AT ALL. Very odd. No real directory structure. For OS/400 you had to compile files and the entire 'file system' was one huge relational database. Very bizzare. No layers. No ability to swap out one portion of the operating system for another. Not even realy programs you run or anything like that. It was presented to the user as just one gigantic menu driven system. VSE/ESA is a little bit less like that, but still it's all menus with 'command line' stuff that is NO WERE NEAR anything like a Unix shell. Everything is just one huge program.
Frankly, it's miserable.
That's how I see it anyways. Other people will have different viewpoints.
jhu
11,918
9
it seems as though the term "unix-like" is highly dependant upon, at least from the user's perspective, the software involved. so would windows 2000 with cygwin installed qualify as "unix-like"? similarly would a system that booted only two programs, the linux kernel and bash, qualify as "unix-like"? it's a matter of semantics, somewhat akin to defining the term "game": we know it when we see it, but can't quite put down strict criteria for exact definint characteristics.
Nothinman
30,672
Solaris is the first OS to incorporate the "revolutionary" new file system ZFS!!
And will most likely be the last if for no other reason than the license, the CDL isn't compatible with the GPL so it'll never make it into Linux as-is and that's even if someone cares enough try to port it. And the technical reasons are probably even more of a PITA, you can't copy a 'normal' filesystem from *BSD to Linux or vice-versa and have it work without major changes so doing it from Solaris to any other OS has even less of a chance of working. That and ZFS isn't just a filesystem and has a ton of layering violations to do what they did with it. I think it's possible to do most of what ZFS does already in Linux with the device-mapper and RAID code we have, it's just a lot more work to setup.
NT4 was POSIX compliant and certified and I believe Win2K and XP with SFU installed still count as compliant but I don't think MS did the certification thing again since no one really cares.
jhu
11,918
9
there are rumors (as of yet unsubstantiated) that dtrace and zfs will be incorporated into mac os x/darwin sometime in the near future.
Nothinman
30,672
To me that seems unlikely, I would guess that dtrace requires a lot of kernel support and I can't imagine Apple pushing such huge changes in such a short time. Especially for a debugging tool that most of their users will never see.
jhu
11,918
9
well, stranger things have happened. it'd be interesting if they actually do pull it off.
n0cmonkey
42,936
FreeBSD did it. ;)
DragonflyBSD's Matthew Dillon is also very interested in ZFS support.
Sunner
ALOHA
Quite a bit actually, more the deeper you go pretty much.
ls? Sure, more or less the same, slight differences with some more "exotic" switches and such.
lspci? Try running that under Solaris.
DiskSuite vs LVM/EVMS/md/whatever
The more you scratch...
The day everyone(Linux, UNIX, BSD, whoever) agrees on one standard syntax for "route" I'm going to be VERY happy however.
Since I use the damn command on a bunch of different systems regularly, I never get it right on the first try on any of them :(
