Solaris 10 tape read error
rasczak
I am hoping someone here has seen this before and can lend me their insight, it's a baffling problem for me as I am still learning the nuances of Solaris. On a Solaris 10 system, I created a tar [tar cvf] to tape of a large (9gb) zipped windows file (copied the file over via nfs share). My issue is when I bring the tape over to a newer Solaris box, I do a tar tvf just to list the contents and receive an error
tar: tape read error.
I bring this tape back to the old system and it reads the tape just fine. I have used other tapes in the new system just fine, but when I go from this old sol10 box to new sol10 it seems to fail.
No, one is a Seagate dat72 (newer) and the other is an HP dat72. I'm not sure what you mean by hardware compression.
Most tape drives have a setting for enabling/disabling hardware compression of the data stored on tape, I wouldn't assume that is interchangeable between drive models let alone vendors. On Linux I would use the mt command to turn that off, not sure about Solaris though.
http://wiki.zmanda.com/index.php/Hardware_compression
What about dd? I thought you said you were using tar to read/write the tape?
Since tar wasn't working properly for me, I used dd instead to write my files to tape. I'm under a bit of a time crunch and I have no other alternatives at this point.
Ah, so dd worked but tar didn't? Sounds like an incompatibility between those two versions of tar (64-bit vs 32-bit?) then.
