It's only going to get more interesting going forward. Eventually I imagine they'll charge everyone a fee, whether they're on the grid or not.
So, you believe that if you produce the same amount that you use, you should have a bill of zero dollars? If you're willing to completely disconnect from the grid, I think you're right. But, if you think you can produce during the day and sell it to the electric company, and then use their energy at night - and they, not you, should pay for maintenance of all those distribution lines that make it possible... well, I disagree with you. $20/month to be connected to their system is a pretty good deal.
You can have an artesian well and avoid water charges coming into your home and for use on your property. But they get you on the other end, and assume that the discharge all goes into the sewerage system. That's why there are two charges on our water bills. Water and sewer.
Ironically our power went out on Monday (No the solar panels do not produce electricity if the power is out).
When the lineman throws the switch to work on the line they need to make sure that the power is off. If any of the houses with solar are still producing power they could bleed power back into the line. As an industrial safety guy I completely agree with this.Why?
Is the "switch" not smart enough to feed only the house on loss of "line"?
Or are there no batteries?
People who say minimum monthly charges are necessary to pay for the grid miss the point of net metering. You get a credit on your bill of upwards of $0.50 per KWH if you contribute during times of the day when the demand is highest and as little as $0.08 or less when the demand is low, so it's not illogical to think that your net contribution to the grid would be overall worth more than the cost of you being on the grid. In most electricity markets, there are spot prices for electricity that varies depending on demand and the time of day. But that credit is reduced down to $0.035 per KWH if you are a net producer of electricity.
The fact that net metering only gives Wholesale electricity rates to customers who over produce is basically theft. Wholesale electricity generation during peak hours isn't worth $0.035, it's certainly worth more than that. They basically have treated any over production to be worth exactly the same regardless of the time of day it's used. Consumers are only rewarded with net metering when they have high demand for electricity during off peak hours and low demand during peak demand.
The idea that someone could use 200KWH of electricity while contributing nothing will have a similar electric bill to someone who uses 0KWH of electricity due to net metering is ridiculous. The net metering laws benefit the utilities and screw the consumer. Meanwhile, the only people making money off of solar PV are those who go into actual electrical contractual agreements to sell power to the utility grid for far above the over production net metering rates of $0.035 per KWH.
NPR did a story about California having more power from alternative sources than they know what to do with,they have an independent system that isn't connected to any other states power grid, and they have to keep the gas burning plants running in case clouds go in front of the sun and the solar production drops.
Multijunction solar PV at the prices of today's solar is what would be needed for people to go off grid. Solar currently is too inefficient at this point so it takes up tremendous amount of space so it works great in the summer but crappy in the winter. I hate the way the utility companies have worked to stifle solar PV production and uptake because my dream would be for the suburban communities to produce excessive solar PV in order to feed the city so that there wouldn't be any need for power plant creation/generation.
I bet it is a fee for the consumer to use the power company's distribution system when power is back-fed into the utility's system. Seems fair.What does a "infrastructure cost" allegedly cover? Is it a legitimate cost, or a "cause we can" charge? Getting paid wholesale rates should be expected. That would be like drilling oil on your property, and expecting a refiner to pay you retail.
Again, this can't work because solar does NOT produce power during peak usage. Areas with high heat during the summer, the hottest time of the day is also when solar is near its lowest product level. From what I am reading, utilities are having an issue already with surging electrical use during the late afternoons combined with collapsing output from solar during the same time. In California in the summer peak usage happens at around 6 to 7, and in the winter it is 7 to 8. Solar output it is near its lowest at these times of day. This is wear I think batteries could be used, it would store the power when it is generated in the noon time, and pump it back to the homes and system in the late afternoon when demand is highest.
Hello, I am from the future. We invented something called a "transfer switch" which isolates the house from the line in, in case power is lost from utilities. People from the future will be required to use it when they have a back-up generator wired to their house.When the lineman throws the switch to work on the line they need to make sure that the power is off. If any of the houses with solar are still producing power they could bleed power back into the line. As an industrial safety guy I completely agree with this.
I don't have batteries.
In summer the sun starts to come up at around 3:30-4:00, though not quite enough for solar to produce much, but it would probably start to produce a bit by 5-6 once it breaks the horizon. Then stop producing by 9-10pm or so.
We just hit the summer half way mark not too long ago though, so the days are going to start to get shorter.
Power Engineer. How do you think it will end? Seems like it is going to be like a bandage being pulled off slowly...long and painful.
Overall electrical sales are flat, even though new building continues. So we have even more infrastructure cost and no new revenue to cover it. And solar continues to advance.
I wonder if it will just be added to the property tax bill at some point.
Eventually, I think solar will improve to the point it is just another part of the new home build, along with hvac and plumbing. But I don't know about commercial use. Unless tech improves leaps and bounds, I don't know how heavy commercial users will get by without the grid.
Why?
End? I'm not sure there will be an end, at least not in the foreseeable future. My guess is that the string of technology improvements in solar energy and storage will continue, and the speed and nature of these improvements will continue to "disrupt" our picture of what a utility is and should be. Even if we reach a 100% renewable future, I suspect their unpredictable, intermittent nature will continue to put a value on spreading their outputs over larger load areas through bidirectional use of the distribution and transmission infrastructure. Remember that this is at best an educated guess...
Not sure where you live, but $0.50/kWh ($500/MWh) is way, way too high. Are you sure you haven't slipped a decimal point? Spot energy prices in the West are closer to a tenth of that (thanks in large part to fracking and the cheap price for natural gas).
Last week's peak prices ranged from $20/MWh ($0.020/kWh) to $65/MWh ($0.065/kWh); off-peak prices were half that. And it was a hot week in southern California.
Frankly, an average price of $0.035/kWh for net metered energy might be a pretty fair valuation of its value. And IMHO you still need to pay an infrastructure charge for the use of the infrastructure when your instantaneous "net" isn't zero.
My two cents...
On E-6 TOU in the third tier, during peak hours in summer, rates can easily reach $0.50 per KWH. If you have Smart Rate, they reach $0.60 per KWH during the designated hours.
The only scenario I can think of when $0.035 per KWH is a reasonable price for electricity is when that electricity is produced at 7am on a Sunday. Otherwise, it's really an undervaluation for the electricity. Remember, PGE has agreements in place for solar PV generation where for every KWH produced, regardless of time of day, you get $0.20 per KWH. Should have signed up for the generator credit instead of the NEM credit as I'm a net producer.
