Matthias99
- Oct 7, 2003
- 8,808
- 0
- 0
Originally posted by: dclive
That's not correct, nweaver.
You can break the mirror and then you'll be able to boot the single drive, true - I was thinking of RAID0/5 when I said that.
As long as the HAL hasn't changed and you put the right disk drives *prior to* moving from one motherboard to another, you'll be fine.
With Windows mirroring, maybe.
With a RAID1 set up by a controller (onboard or not)... hit or miss. Sometimes they have some extra data stored on there with array information (usually at the beginning of the drive) that prevents Windows from properly recognizing the partition(s). I would NOT count on being able to take a single disk out of a RAID1 and just being able to use it like that as a standalone hard disk. If you put it on the same controller (or, usually, a controller in the same family), you'll usually be OK.
