SoB Stats for Jan 1st and 2nd
TAandy
3,218
Originally posted by: Insidious
try re-booting without stopping it first
-Sid
really???
and there's me thinking i'd do it nicely, when i should have just put the (re)boot in, literally :)
thanks sid :cool:
Spacehead
13,067
9,858
Originally posted by: TAandy
...then, after pc has rebooted, it starts again from scratch. not sure if it's running the same test again or not though.
Look in your SB folder & see how many files there are that start with 'z#######'. If you're only running 1 instance there should only be 1 of those files. If there are more than 1 then the client keeps starting new tests after a reboot.
does sob not save intermediate steps of the test it's working on?
It should. Not sure why it isn't.
TAandy
3,218
just had a quick peek, only 1 file in there beginning with z!
TAandy
3,218
Andy, you still having problems with it not saving after reboot?
hi space,
nope! haven't rebooted for a while :)
