<< And a sam locks onto you and is homing in. WHat the hell are you supposed to do and what should you not do?.
This question was inspired by the sequence in the movie, Behind Enemy Lines.
-- Should you light up the afterburners and try to outrun it? Or will the increase heat signature make you a better target?
-- How fast do sams fly at and how high can they hit you?
-- How many G's can a sam pull?
-- Does dropping fuel tanks and/or firing a missle at a mountain for example - causing a large fire - fool the tracking of a SAM?
-- Out of the 4 planes mentioned, what plane would you want to be in if a sam was chasing you.
-- Do chafes and flares work, and what is a chafe?
My pick: F15 because of the thrust/weight...... Am I wrong? >>
Gs? SAM? ur kidding, right? A SAM can pull FAR more Gs than a human can sustain...in other words, it's a non issue. Now, an F-16B (specially modified with thrust vectoring/larger wing) can pull nearly 30...that'd kill the human, but still. So I imagine SAMS can pull massive G...BUT, they are not incredibly manuverable--short stubby wings, flying at mach2-3
Speed/Height: Depends...REALLY depends. They have SAMS that can reach into 70,000 feet up. They have SAMS that can barely reach past 5000ft up. Speeds? Mach 2-3 from what I remember.
And it's chaff, not chafe. Chaff is just a big clutter of metal pieces, used to clutter the tracking radar, so it will lose the lock. Flares generate a LOT more heat than burners; i think they're usually something similar to white phosphorus. And yes, they do work, although modern missiles are becomin more and more adept at detecting what's a decoy, and what's a real target. Beyond that, if the missile is guided from the ground, then it's success depends on the operator's ability to decide what to fly at.
Go ahead and punch burners if a SAM locks on--there's no way in hell you can cool down enuf to break a heat seeker, so u might as well try to slow the closure rate whilst dropping flares. Also, you don't just drop flares...you jink (manuver randomly), and drop flares/chaff right before executing a sharp turn--suceed in confusing the missile for a second, and then quickly get out of its scanning area.
Dropping tanks, bombs, or missiles CAN fool a heat seeking SAM...an earlier one...the most modern heat seekers can avoid that.
Other thoughts: F-15's weight:thrust is NOTHING compared to the F18. and the F16 can out turn them all hands down. F14 is good because of the phoenix missile, and it's supremely powerful radar system. The variable-geometry wings allow it to act as an interceptor and a fighter, (mutlirole) which is vital as carriers have very limited space. Other than that, it is not very manuverable (u seen how large that thing is?), compared to say, MIG-29 or Su-35...F18/16 can out turn it too...I think the F15C can as well.
And, an F-18 would probably be a 'best' choice--it's decoy system is far more advanced than the other 3 planes. It is equipped with a decoy that it can release on a cable--this is to fool the missiles' targeting systems; it has the same radar signature as the F-18.
