So now there are 12 planets....
Thraxen
4,683
:thumbsdown: to the people asking, "Why does it matter?".
Anyway, it looks like they are breaking the planets down into different classifications, with the very small ones being called "plutons".
Atheus
7,313
Originally posted by: JEDI
wtf?~ 12 planets from 9?
ok.. ceres and xena i've heard of. Where did this 12th planet come from?!
Charon is a moon of Pluto and under the new definition would be consider a planet, or "plutons"
wtf?! how does a very small moon of a very small planet get to be a planet? yet Earth/ saturn/jupiter's moons arent?
Charon is about the same size as Pluto, so it's part of a double planet rather than a moon.
MrPickins
700
From what I gather, they are a binary ststem, also. Meaning neither orbits each other, instead both orbit a barycenter in space between them. Thus, neither is a moon.
mercanucaribe
Banned
Oct 20, 2004
9,763
That's the way all orbits are. It's impossible for any planet or star to not wobble from its satellite's mass.
Aug 5, 2006
34
From what I've heard the reason that the Moon is still a moon but Charon is a planet has to do with the location of the center of mass of the planet-moon system (relative size.) While the Moon is indeed much larger than Pluto the center of mass of the Earth and Moon combined still lies below the Earth's surface due to the Earth's larger mass relative to the Moon. Pluto and Charon are much closer in size to each other and thus the center of mass of their system is relatively farther away from either body.
GreenGhost
1,272
Originally posted by: freshgeardude
according to this xena is the 10th planet and at this rate every thing they see circling the sun that has a rock around it or neer it the will call a planet so in like 10 year there will be like 25 planets!!!!!!
Grabrielle has hotter than Xena, but she was made to look like an ordinary sidekick.
EKKC
5,895
cant they name the new planets Tatooine, Death Star or something cool
SagaLore
24,036
21
Perhaps the true definition of a planet should be any astronomical body of mass capable of supporting life with an atmosphere (not necessarily meaning an atmosphere exists, just that the amount of gravity could make it possible).
The rest of them are just solar masses.
preslove
16,754
63
They need to just make an arbitrary definition using the mass of the object to call it a planet. Anything smaller than mercury is not a planet.
pontifex
43,804
46
hot redhead ftw!
although i think i saw some shots of her in later seasons where her hair was cut really short and dyed like platinum blonde.
yhelothar
18,407
39
Originally posted by: JohnCU
Originally posted by: outerheaven
Originally posted by: dug777
They're just sucky little rocks :p
Some are just frozen masses of gas on some rock.
I think in order to be called a "planet," a celestial object must have a significant gravitional field and contain an atmosphere. Of course the scientists are debating that now.
mars doesn't really have an atmosphere
Uh yeah it does..
It's made up of carbon dioxide.
You must be thinking of mercury.
KDOG
14
I don't know why they just don't use Pluto as the minimum standard for a planet. Any bigger - planet. Any smaller - just a rock.
Triumph
13
But what about the converse, Jupitor and Saturn are pretty much all atmosphere. They may have a rocky core, we don't know, but if they do it is very small in relation. Actually, it could be argued that Jupiter is in fact a failed star. I can't remember the exact name for it, but when a gaseous entity has so much mass and a certain radius, it will collapse on itself and begin the process of nuclear fusion. I think Jupiter is just this side of that requirement.
Baked
36,052
17
Well that's just retarded. Next thing you know, they'll catagorize all the objects in inner and outter asteroid belts as planets. Some of the large planets in the solar system have satellites bigger than pluto, a planet which should've been catagorized as an outter asteroid belt object. These scientists are puffing the good shed overtime in their little labs.
flexy
8,464
155
those scientists must be smoking the crack pipe.
Everyone knows the 12th planet is Planet X (or Nibiru)...inhabitated by the Annunaki.
dvmba$$es scientists :)
jagec
24,442
Bacteria live pretty much anywhere.
