so, my toilet is clogged and.....
aircooled
15,965
plunge first, then snake if need be. Snakes are pretty cheap nowadays.
I keep a snake around mainy for hair clogs in the tub....
Bootprint
9,847
Originally posted by: BatmanNate
Originally posted by: kermalou
i dont want to pay for some fat ass plumber to come to my room and charge me money for this crap.....what would be the cheapest way to snake?
Garden hose. ;)
Or do you have any extra Network cable around?
The RG-58 we used for token ring would be pretty good.
EmperorIQ
2,003
wtf? baby wipes, imma try that now~! um, i usually go out to the backyard and find long sticks, if that doesn't work, then yea, snake
Ornery
17
How to Unclog a Toilet
  1. Plunge... First, you obviously want to use your plunger to try and loosen any clogs. Start by making a seal over the hole-in-the-bowl with the plunger. Push down slowly and pull back quickly. Start by doing this at a slow pace and then working up speed.
  2. Use a toilet snake/auger... I dislike this step because it can scrape the porcelein, but it's necessary if the plunger doesn't do the job. Make sure you get a toilet snake/auger, as a sink snake/auger will scrape the porcelein on your toilet. Trust me. Work the snake as far back into the hole as possible, trying to dislodge any tissue or solid matter (mmmm... tasty).
  3. Pour a bucket of water... If the snake still doesn't let you flush the toilet successfully, this is what finally did it for me. This step can also be used before the plunger in the case of a very small clog, but works well as a last step with a stubborn clog. Get a normal sized bucket and fill it between 1/8 and 1/4 of the way full with warm water. When the water in the toilet is at its lowest point (usually with clogged toilets, very little water is left in the bottom), pour the water directly into the hole-in-the-bowl from about waist-high. The pressure of the water being poured into the bowl does a surprisingly good job at disloding the remaining clog. You may need to repeat this step once or twice.
tyler811
5,385
This happens every time I eat a triple cheese pizza, taste good going down but hurts like hell coming out, plugs the toilet everytime. My plumber thanked me the other day for paying his kids way thru med school
Dacalo
8,778
4
Damn, once back in college a friend of mine dropped a bomb in a toilet and it got clogged.
I spent the next 30 minutes using a plunger, with toilet water with crap splashing all over my body :|
i just started to use baby wipes instead of toilet paper and am thinking that is what is clogging my toilet.
every other time the toilet was plugged, the plunger worked great, but ths time no good....
Yeah.
You can't throw babywipes into the toilet. We've used babywipes all my life, and we found out the hard way they have a habbit of clogging toilets.
We just throw them into the waste basket. Of course, if you ONLY use wipes, and no toilet paper... that could be pretty nasty. We use toilet paper first, and then wipes.. so there is barely anything on the wipe, it doesen't stink or anything.
TMI TMI TMI!!!! :Q :disgust:
Spoooon
11,563
203
You're a pretty good friend. If one of my friends clogged my toilet, he's the one that's going to take care of it.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
agreed.... If you're really daring, also get a pair of long latex gloves.... reach in a grab whatever you can...
And, before calling the plumber, disconnect water line, 2 bolts holding toilet down, and access the drain that way...
Gage
429
Rollwipes by Cottonelle
COTTONELLE FRESH® pre-moistened wipes are available on a roll to give you a convenient choice between moist wipes and dry toilet paper everytime. A clean, fresh feeling for the entire family.
Cleans and freshens better than dry toilet paper alone.
Alcohol-Free.
The dispenser simply snaps into nearly any standard toilet paper roll hanger, and holds a roll of COTTONELLE® toilet paper too. See how it works and view attachment instructions.
Available in: Starter Pack and Four Cartridge Refill Pack
Flushable
Sewer and septic safe.
90 day money back guarantee.
Alcohol-Free.
Flushable
OMG! Too cool!
SagaLore
24,036
21
Baby wipes aren't flushable. You have to use the flushable wipes made specifically for that.
SagaLore
24,036
21
Yeah.
Hmmm this baby wipe phenomenon is new to me. I didn't know people used them.
Mostly women starting using them... keeps their in-between much cleaner and "fresher". :D
shimsham
10,765
the thought of my butt crack being wet makes me shudder. my wife and i used them when we would run out of TP. i hated it. i like to feel dry.:eek:
a bucket of water works well. ive found hot water works best.
good luck
:beer:
Shawn
32,236
53
Yeah.
The stuff you learn on ATOT........ ;)
I always flush mine. I just don't put more than 2 down at a time per flush.
Shawn
32,236
53
Yeah.
